is it possible to connect access switch uplink 1g to core switch 10 g
Moh24100
Hi everyone
I have switch 6807XL working perfectly with uplink 10G access switch , but when connect switch 2960 uplink 1gb the interfaces remain down
please advise
thank you.
3 Accepted Solutions
Leo Laohoo
Both ends must have the same speed and the same wavelengths.
@Moh24100 wrote:
I am using media SFP 10G-sr & GLC-SX -MM
One side is 10 Gbps and the opposite end is 1 Gbps.  Both ends do not have the same speed, therefore, the link will stay down.
   - @Moh24100                    >...yes 6807Xl its Fiber
                           As stated by others for fiber both ends must support the same-fixed speed,
  M.
7 Replies 7
M02@rt37
Hello @Moh24100,
Do you check the compatibility matrix regarding your platform ?
https://tmgmatrix.cisco.com/
Best regards
marce1000
  - It depends on the interface type on the 6807XL , if it's fiber then the speed is fixed, and there can be no conflicts,
  M.
Leo Laohoo
Moh24100
@marce1000  yes 6807Xl its Fiber
  M.
Joseph W. Doherty
In addition to what the others have already noted, some optical ports, e.g. SFP+, will support different speed optical transceivers, but, usually, the optical transceivers need to be alike on both ends.
