IS it possible to run CLI commands on switch through DCNM?
eyalg
Instead of API calls?
Thanks!
I don't think you have direct CLI access in DCNM.  You can use Configuration Delivery Management to configure a device, which basically means you use ASCII files that adhere to a specific format:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/dcnm/system_management/configuration/guide/sm_dcnm_cg/sm_cfg_deliv_mgmt.html
Thanks for the answer,
That's what I thought
