07-17-2019 08:13 AM
Hey there,
my question is:
Is Switches have MAC address?
thanks
07-17-2019 08:21 AM
07-17-2019 09:28 AM
07-17-2019 11:28 AM
Hello Joseph,
I think the real discriminator here is the support of any form of STP protocol.
STP protocol requires each port to use its own MAC address as source MAC address of STP BPDUs sent out of the port.
In addition to MAC addresses used by ports and by port-channels there are MAC addresses used to build the STP Bridge ID.
In modern IOS switch a single MAC address is enough thanks to the use of extended system id as the STP two bytes priority is built as base priority + Vlan-id
And base priority must be a multiple of 4096 0, 4096, 8192 and so on.
Even an unmanaged switch running 802.1D classic STP needs to use MAC addresses as explained above.
The port specific MAC addresses are used in Cisco switches also for other L2 signaling protocols like CDP or LLDP and LLDP MED.
What a L2 switch cannot do is to change a user frame, because it needs to act as a transparent bridge.
Hope to help
Giuseppe
07-17-2019 12:25 PM
07-20-2019 12:45 AM
07-20-2019 08:06 AM
07-17-2019 10:23 AM
yes they do have unique MAC address each device.
