is there a way to modify the flap-values on err-disable?
tomek0001
Level 4
Level 4
Does anyone know if that is possible to change
ErrDisable Reason Flaps Time (sec)
pagp-flap 3 30
dtp-flap 3 30
link-flap 5 10
.. the link-flap to let's say 3 flaps within 20 seconds?
thanks
Edison Ortiz
Rack1SW4(config)#errdisable flap-setting cause link-flap max-flaps 3 time 20
Rack1SW4#sh errdisable flap-values
pagp-flap 2 60
dtp-flap 3 30
link-flap 3 20
Edison.
Edison Ortiz
pagp-flap 2 60
dtp-flap 3 30
link-flap 3 20
Edison.
Hello Edison,
Thanks very much for your hint. How come that this command is not documented at all? I have had a look on various versions of IOS Command References for 3560 series switches and while the command is indeed available in the IOS, it was not described in the documentation.
Best regards,
Peter
Thank you, That's exactly what I was looking for.
