Is there any way to create CISCO 2960 Stacking with RJ45 cable
Prawal3001
I want to stack 2 x CISCO 2960 switches, but they are in different racks so I cannot do it using stack cable. Only option I have with my patch panel is to connect RJ45 cables. Is there any way I can do it with RJ45 instead of Stack cables?
Please help!!!
balaji.bandi
No you can not do stacking using RJ45
never tested myself, try flex link :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swflink.html
BB
Joseph W. Doherty
I haven't "looked" at the 2960 stacking cable options, but in the (possibly similar vintage) 3750 there was an optional 3 meter stacking cable, used for things like cross stack rack connections.  I.e. perhaps Cisco offered longer stacking cables for the 2960s too.
NetworkDave
Prawal3001,
As @Joseph W. Doherty mentioned, Check into a 3 meter version of the Flexstack and Flexstack-Plus cables. If that is still not long enough, then your other option would be to use Flexstack-Extended. Switch Model, IOS, and cost (requires Flexstack-Extended modules) are key factors to consider.
It might come down to either moving the switch or doing without the stacking feature. HTH
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
Prawal3001
Thank you all for your replies. It seems I have to do without stack feature.
