Is there limitations for Cisco-3560 Switch
cisco__kaushik
Level 4
Level 4
Problem When we are connecting a 7206 vxr npe-G1 gig interface with a cisco 3650 swith's fastethernet packet starting drop when the trafics flowing from NPE g1 to Switch more than 40mb.
Is there any limitations that seitch fastethernet interfce can support only40 mb data
Joseph W. Doherty
What stats are using to measure the "more than 40mb"?
It's possible to have very bursty traffic encounter drops yet not see a high average data rate. If this is the case, and you're using FIFO, you might try increasing the outbound queue depth and see if the drops decrease.
It's also possible, with FIFO, to encounter multiple flows having synchronous tail drop. If this is the case, using WRED or WFQ might decrease the drops.
I can brief you.
we are measuring through command sh interface ......
case 1 )if 1 connect giga port ----- giga port ( both site like NPE g1 & swich site)
no drop
case 2 ) if npe g1 is giga port and switch site is fastethernet then drop start
I think qos will not help in this case
it may be a limitations but i am not getting the actual doc on this
glen.grant
You should not start seeing drops on a fast ethernet until it is running over 90% of its rated bandwidth . How are the interfaces set on each side ? If for some reason the 3560 negotiated a half duplex link then yes you might start seeing drops at about 40% .
I drought on this , if data flow 90% so other thing like routing protocol, keep alive, other stub wil take some b/w.
other parameter setting is ok
I think 45mb % max can flow with fastether port.
but I d'n;t have ant doc on this
if you have pl shara.
