isdn problems
carl_townshend
Hi all, Is it possible that an isdn line can be set to only be allowed to call one way ? I have a router where it raises the line one way, but when I try to make a call from the other side, it does not work ?
hope you can help
cheers
Carl
5 Replies 5
spremkumar
Level 9
Level 9
Hi Carl
Are you trying to configure dial out and block dial in or the other way around ?
can you throw more clarity on the same ?
regds
Hi, I want it to dial both ways.
Hi Carl
You can do it both the ways. But make sure you have different profiles created for dial in and dial out and also make sure that both your isdn channels are used for dial out when you are trying for dial in.
regds
Hi there, I have got the logs of the router and it is coming up with "call rejected - unbindable, and an error 0x8095-call rejected, can anyone help me with this ?
thanks
Carl
Hi Carl
As per the supporting doc its been advised to config ppp authentication chap | pap [callin] under the physical interface...
Hope this helps..
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_tech_note09186a0080094e6c.shtml#incoming_do_not_connect_properly
regds
