ISR4300 Spanning-tree issues with BDI
Baz1977
Hello friends
I am in need of a help.
I am currently working on a setup for a client. Topology is simple. There are 2 sites connected together over 2 P2P links. These are both layer 2 links.
I recently replaced their EoL cisco 3500 switches ( 4 they had ) with 2 ISR 4300 to act as their routers and 2 3750 for one of the P2P links.
See below diagram :
CE1:
int BDI 666
encapsulation dot1Q 666
interface GigabitEthernet0/0/2
service instance 666 ethernet
encapsulation dot1q 666
rewrite ingress tag pop 1 symmetric
bridge-domain 666
interface GigabitEthernet0/0/0
encapsulation dot1q 2100 second-dot1q 666
rewrite ingress tag pop 2 symmetric
bridge-domain 666
l2ptotocol peer
spanning-tree mode pvst
spanning-tree vlan 666 priority 24576
CE2:
int vlan 666
ip add 192.168.1.2 255.255.255.0
int f 0/1
sw mod trunk
sw trunk allowed vlan 666
spanning-tree vlan 666 priority 20480
interface G 0/2
sw mod trunk
sw trunk allowed vlan none
CE3:
int vlan 666
ip add 192.168.1.3 255.255.255.0
int f 0/1
sw mod trunk
spanning-tree vlan 666 priority 12350
interfave gi 0/2
sw mod trunk
CE4:
int BDI 666
ip address 192.168.1.4 255.255.255.0
bridge-domain 666
bridge-domain 666
l2ptotocol peer
spanning-tree vlan 666 priority 8192
All works great at the moment as the link between CE2 and CE3 is not allowing vlan 666.
I can ping all 4 devices from everywhere.
As soon as I allow the vlan through the trunk between CE2 and CE3 , I see a loop ( mac address flap ) and I lose the network.
I allowed it for 30second to make sure it is not spanning tree sorting itself out, but no, kept getting the message.
So I am at a bit of a loss as I seem to have followed the setup guides I have seen here but still getting the issue
It should be noted that if I issue the command:
sh spanning-tree vlan 666 on the ISR, I only see the G0/0/2 being listed in the output and not gi 0/0/0.
but if I do sh spanning-tree bridge, then I see
vlan666
vlan2200
and I can't see the status of the port to see if it is forwarding or blocking or ... when I use the command sh spanning-tree bridge
Any help will be appreciated as I am struggling with this and time is noton my side.
Reza Sharifi
The ISR routers are mainly used for layer-3 routing and not so much for layer-2 switching. I am not sure, why you would replace 2 switches for 2 routers when everything is layer-2. If everything is layer-2, why do you have OSPF area 0 in the middle of the diagram? If you want to keep everything as layer-2 and extended vlan 666 from one site to another, replace the 2 routers with 2 switches and move the second connection (marked in red) to the switches that are directly connected together (c2 and c3), and create a Portchannel. This will give you link redundancy and you can use both links at the same time without being concern about STP.
C1------C2--PO--C3-----C4
Hi Reza
There is a l3mpls going into the isr routers. I haven't got that in the picture as it is not relevant here. Hence the need for the ISR.
