ISR4331 how to setup port bridge
Miyuki
Hello
I have following setup, ISP add second router, they have configured HSRP, VIP: x.x.x.105, it used to be just one so now I have one more connection on booth (two on every)
I need to modify setup to port bridges on selected (red circle) routers but I cannot find any bridging option
Routers are ISR4331
It have no bridge option in interface menu
Can you please help me ?
2 Accepted Solutions
Reza Sharifi
Have a look at this with config example:
interface Gig0/0/1
   service instance 25 ethernet
     encapsulation dot1q 25
     rewrite ingress tag pop 1 symmetric
     bridge-domain 25
interface Gig0/0/2
     bridge-domain 25
interface BDI25
   ip address X.X.X.X 255.255.255.0
   no shut
link:
https://supportforums.cisco.com/t5/wan-routing-and-switching/bridge-configuration-at-isr-4000/td-p/2665791
I don't have a 4331 to test with, but if it gives you the option you can try untag, if not than you have to give it a vlan id (the same way as the example).
7 Replies 7
Reza Sharifi
interface Gig0/0/1
     bridge-domain 25
interface Gig0/0/2
     bridge-domain 25
interface BDI25
   no shut
link:
And if I don't want to setup any vlan, what should I set to encapsulation? default or untagged ? Without encapsulation setting bridge domain is not accessible, that confused me
Thank you much
It works right
config:
interface GigabitEthernet0/0/2
no ip address
negotiation auto
service instance 1 ethernet
encapsulation untagged
bridge-domain 1
interface BDI1
description Wan-Bridge
ip address x.x.x.x 255.255.255.240
Question on this solution.  In order to do this do I require any special license like AppXK9?
Can you help listing all the configuration ?
Current configuration : 1466 bytes
! Last configuration change at 12:55:03 UTC Mon Jun 14 2021
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ip routing
login on-success log
subscriber templating
license udi pid C1117-4P sn
no license smart enable
diagnostic bootup level minimal
redundancy
mode none
bridge-domain 100
controller VDSL 0/2/0
operating mode vdsl2
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
no ip address
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface ATM0/2/0
no ip address
shutdown
atm oversubscribe factor 2
no atm enable-ilmi-trap
interface Ethernet0/2/0
no ip address
no negotiation auto
no cdp enable
service instance 100 ethernet
encapsulation default
bridge-domain 100
interface Vlan1
no ip address
bridge-domain 100
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
login
end
