Issue Nexus 3048
ahmad20920
hello and welcome  an issue on cisco switch 3048 reset several time
Reason :Reset triggered due to HA policy of Reset
Service: igmp hap reset
Version 6.0(2)U5(1)
how can i solve this issue to prevent switch reset
Reza Sharifi
This is most likely a bug related issue in the version of Nexus OS you are running. Open a ticket with Cisco and they will advise you with a solution.
6 Replies 6
Reza Sharifi
marce1000
  - If desired you may also look into the current advisory release for your platform and upgrade . Check if the problem persists afterwards or not.
 M.
There is a bug starting from version 6.0 (2) U6 (1) to 6.0 (2) U6, and fixed starting from 6.0 (2) U6 (8), 6.0 (2) A8 (3) and 6.0 (2) A6 (9) ... Update version.
writemyessay.onl
Do you have a bug ID ?
No i have no bug  how can i get it
So there is no solution to minimize nexus restart at this version so update  is the only solution
