Issue on Implementing StackWise Virtual
Raj_82
I'm attempting to set up Cisco C9500-40X-A Switches with stackwise-virtual configuration. The installation is new.
The port enters the "Not connected" state. following the Switch's virtual link configuration. I initially believed there was a problem with the SFPs or the Switch port, so I tested several ports and SFP modules. the same problem. Additionally, there is no cable issue.
Same software version,license type, StackWise Virtual domain
Configuration on both the switches
stackwise-virtual
domain 1
stackwise-virtual dual-active-detection
inter ran ten 1/0/39, ten 1/0/40
stackwise-virtual link 1
Additionally, I tried to modify the Switch number to 2 and the Switch Priority on Switch to 15.
The stackwise-virtual dual-active-detection link is operational following configuration, but the virtual link is not.
Can somebody assist me in troubleshooting the problem? I've included the configuration file as a reference
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9500-series-switches/216537-troubleshoot-svl-on-catalyst-9000-switch.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Raj_82
Thanks for the reply, we have QSFP-40G Direct-Attach Cables. we are unable to use because the ports are 10G and it is not supporting to use as to conenct svl. so i have tried to configure the SVL with two 10G RJ45. it is not coming up. The port is working after configuaring SVl it is going into down state.
Our switch model is C9500-40X.
is there any limitation to use 10G RJ45 for SVL?
do we need use fiber SFPs?
