issue on switch 6500 policy map inbound
GRTO
Hello All,
ON switch 6500 i have configured an interface vlan x and applied policies on inboud and outbound directions as per below:
interface Vlanx
ip address 1.1.1.1 255.255.255.0
service-policy input VlaX-in
service-policy output VlaX-out
  Policy Map VlaX-out
    Class class-default
     police cir 2048000 bc 2048000 be 4096000
       conform-action transmit
       exceed-action drop
       violate-action drop
  Policy Map VlaX-in
    Class class-default
       exceed-action drop
       violate-action drop
But the problem i am facing is that the policy outbound works ok , but the policy inbound doesnt work at all. specifically it doesnt match anything
show policy-map interface vlan X input
VlanX
  Service-policy input: VlaX-in
    class-map: class-default (match-any)
      Match: any
      police :
        2048000 bps 2048000 limit 2048000 extended limit
      Earl in slot 6 :
        0 bytes
        5 minute offered rate 0 bps
        aggregate-forwarded 0 bytes action: transmit
        exceeded 0 bytes action: drop
        aggregate-forward 0 bps exceed 0 bps
Has anyone faced this issue?
gerta
Hi, GERTA!
You should specify "mls qos vlan-based" on the phisical interface for that vlan.
