Issue regarding upgrading ios in C9200
kevin2001
Hi, we have an upgrading ios issue when upgrading new ios to cisco 9200 switch. Please see below. after entering copy command, the transferring starts. it show a lot "O" among exclamation. It is normal? and The uploading is completed successfully?
Mark Elsen
 - "O" means that a packet was received out of sequence during the tftp transfer. This is not a problem;
    verify the md5sum of the transferred image on the switch (too) using verify /md5 flash:<cat....SPA.bin>
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
  M.
       Beauty and terror
      Just keep going
       No feeling is final
kevin2001
Thank you very much for your reply.
How about the below info during copying ios? some point " . " among the exclamation
Jan Rolny
Level 3
Level 3
A period (.) indicates a timeout. So, no data are transferred.
you can find the answer for instance here
https://community.cisco.com/t5/switching/tftp-image-file-tranfer-out-of-sequence/td-p/1986184
and I found something also here on cisco.com
https://www.cisco.com/c/en/us/td/docs/ios/ios_xe/fundamentals/configuration/guide/2_xe/cf_xe_book/cf_file-transfer_xe.html
Best regards,
Jan
parickwarren1
Hey, glad you got your answer. Just make sure to double-check the file that was uploaded to confirm the transfer actually completed cleanly. You can find the md5 checksum under the file info oin the cisco downlolad page for that version.
