Bookmark
Subscribe
2720
issue when update ios for 7206 router
Dr.X
Level 2
Level 2
hi all ,
the ios on router was 12.4
i put the ios
c7200p-adventerprisek9-mz.152-4.M5.bin
in disk2  , of router
and added
boot system flash disk2:/c7200p-adventerprisek9-mz.152-4.M5.bin
after that  ,
i restarted the router
i have the followign logs :
7200Gateway#reload
Proceed with reload? [confirm]
*Jan 11 15:24:11.469: %SYS-5-RELOAD: Reload requested  by m0ulngateway on console. Reload Reason: Reload Command.
*Jan 11 15:24:11.681: %BGP-5-ADJCHANGE: neighbor 213.244.66.77 Down Peer closed the session
System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Socket jumper: not present Failsafe jumper: present = normal
FPGA revision 0x00000026
C7200 platform with 2095104 Kbytes of main memory
Readonly ROMMON initialized
Self decompressing the image : ################################################################################################################################# [OK]
%SYS-6-CLOCKUPDATE: System clock has been updated from 15:26:31 UTC Sat Jan 11 2014 to 17:26:31 Israel Sat Jan 11 2014, configured from console by console.
% No interface specified for interface_command
X121 address and queued type can not be configured on the same rotary group 1
%SYS-3-IMAGE_TOO_BIG: 'disk2:/c7200p-adventerprisek9-mz.152-4.M5.bin' is too large for available memory (46143512 bytes).
%SYS-6-READ_BOOTFILE_FAIL: disk2:/c7200p-adventerprisek9-mz.152-4.M5.bin File read failed -- Not enough space.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
boot of "cisco2-C7200" using boot helper "bootflash:c7200p-kboot-mz.124-4.XD5.bin" failed
error returned: File read failed -- Not enough space
loadprog: error - on file open
boot: cannot load "cisco2-C7200"
Self decompressing the image : ########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
*** No sreloc section
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 7200 Software (C7200P-ADVENTERPRISEK9-M), Version 15.2(4)M5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 13-Sep-13 19:12 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco 7206VXR (NPE-G2) processor (revision A) with 1966080K/65536K bytes of memory.
Processor board ID 13252317
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.0
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Warning: The CLI will be deprecated soon
'enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Please move to 'enable secret <password>' CLI
max-reserved-bandwidth 95
% Invalid input detected at '^' marker.
Press RETURN to get started!
focusing on the red  lines above .
is there ANY THING WRONG ?????
AFTER THat i have sh ver :
7200Gateway#sh version
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
7200Gateway uptime is 10 minutes
System returned to ROM by reload at 17:24:07 Israel Sat Jan 11 2014
System image file is "disk2:/c7200p-adventerprisek9-mz.152-4.M5.bin"
Last reload reason: Reload Command
export@cisco.com.
focus on bold line ,
did the router get the new iso without problems ????
wish to clarify
regards
amsodhi
Issue: - You have insufficient space in disk2:
All the .bin files are zipped files, router expands .bin (IOS files) at the time of boot.  (Actual size of the IOS file is much bigger than the zipped file, so don’t think that if you have IOS code in the disk your job is done. You need to make sure that there is enough space in the disk so that zipped file may expand at the time of boot).
http://software.cisco.com/download/release.html?mdfid=282188585&flowid=820&softwareid=280805680&release=15.2.4S4&relind=AVAILABLE&rellifecycle=ED&reltype=latest
To run c7200p-adventerprisek9-mz.152-4.M5.bin, you need to have minimum free Flash/Disk: - 256 MB and DRAM of 1024 MB.
Currently you have only 126.4 MB available space in the disk. That’s the reason you are getting an error.
Don’t forget to rate this solution :-)
-Amant
7 Replies 7
Reza Sharifi
It appear that the router is complaining about not having enough room on the flash card, end though you have the correct amount of flash that is required which is 256Mb.  You also have enough memory for this IOS.  So, I would try to clean up the flash card, load the new IOS on it and than reboot it.
Remember, this will cause long outage if this router is funtionaing in a live network.
Dr.X
Level 2
Level 2
hi ,
want to say that the old ios images stayed in the flash
note that flash in 7200 is called disk2
so :
7200Gateway#sh disk2:
-#- --length-- -----date/time------ path
1    39814568 Sep 21 2010 11:23:42 +02:00 c7200p-adventerprisek9-mz.124-24.T4.bin
2    39812968 Jan 24 2013 14:07:38 +02:00 c7200p-adventerprisek9-mz.124-24.T7.bin
3       10924 Feb 6 2013 02:59:54 +02:00 6-2-2013
4    50219396 Jan 11 2014 16:37:20 +02:00 c7200p-adventerprisek9-mz.152-4.M5.bin
126349312 bytes available (130154496 bytes used)
you mean that flash is full ?
Yes, the flash seems to be full even though it shows you still have about 126Mb of available space. So, make a backup of all the existing images on the flash, than delete them and than load 152-4 and try it. Hopefully, this router is not is production, as making changes like this causes down time.
Good Luck
amsodhi
-Amant
hi , thanks all alot for reply ,
but another questions
1-
why the bin are expanded in flash ???????
i thought that are expanded in memory ??!!!!
2-
if the space is not suitable for the new ios , why my router could run with the new ios 15 ???
i mean that it should give me an error and dont load the ios ?!!
AND AS WE SEE above , the current ios is iso 15 after reload ?!
3- do i need to update bootstrap when i update the ios ???? or the ios update only is suffecient ??
regards
You are right, whenever Cisco device boots, the IOS files gets loaded on the DRAM.
But in this process, some temporary files are also generated which gets saved in the flash/Disk, that’s the only reason you got these error messages. It’s not recommended at all to have less space in the Flash than what is recommended on Cisco.com. I would say please remove some files from Disk and have minimum 256 MB flash otherwise your router may drop into rommon mode at the time of next reload.
Well, it’s good to upgrade the bootstarp image too. Currently you are running 15.X IOS code, I would say run 15.X bootstarp image on the box.
You may download bootstarp image for 7206VRX NPEG2 from the link below:-
http://software.cisco.com/download/release.html?mdfid=282188585&flowid=1380&softwareid=280805685&release=15.2.4S4&relind=AVAILABLE&rellifecycle=ED&reltype=latest
If you want to know the procedure of the upgrade, click the link mentioned below:-
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf010.html#wp1017654
-Amant
-Amant
thanks alot
very nice explanation
regards
