Issue with 3850-24XU removed from stack- urgent
carl_townshend
Hi all
we seem to have an issue with one of our 3850-24XU switches, it is running ver 03.07.05.E.152-3.E5
The switch said switch 1 has been remofed from the stack, when I consoled into it, it was stuck at rommon, when I booted it, it came up with the below
Start type: SRV_OPTION_RESTART_STATELESS (23)
Death reason: SYSMGR_DEATH_REASON_FAILURE_SIGNAL (2)
Last heartbeat 0.00 secs ago
PID: 6268
Exit code: signal 6
CWD: /var/sysmgr/work
PID: 6268
UUID: 3005
get_local: failed: No such file or directory
Unmounting ng3k filesystems...
Warning! - some ng3k filesystems may not have unmounted cleanly...
Please stand by while rebooting the system...
Restarting system.
Booting...Warning: Doppler SupMdio read failed!!
With an error message like that, I'd say, yes.
9 Replies 9
Mark Malone
Is it still failed in rommon or is it eventually booting up
Theres a doc to recover failed 3850s
section
Recover from a 3850 Series Switch Boot Failure
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html#anc16
Hi Mark
It tries to boot up but keeps going into a loop then gives up and goes back to rommon.
My first question is why has it failed twice in one week?
Do you think its bad hardware?
we have 5 other stacks running the same software and they are fine.
Cheers
Hello
PID: 6268
UUID: 3005
Could be corrupt/missing files in flash, Suggest look through that document Mark provided seems to provide possible workarounds
Kind Regards
Paul
Carl,
Organize for an RMA.
Does this sound like a hardware issue?
Many thanks
if it wont take a new image in rommon and boot then i would RMA it , especially that it failed twice in space of week
what do you mean by won't take a new image in rommon?
I have not tried copying a new image to it as yet, should I try that first?
cheers
it maybe hardware as Leo said or could have just totally corrupted the image in flash and wont boot it right , if there is another image in its flash you could try boot that from rommon instead or try and boot the switch from USB as another option bypassing local flash
There 2 things id try , if they fail to get it working i would RMA it
TAC may get you to try a method anyway before rebooting
