Issue with ASR Router
kannan.kannan
Hello.
We are facing some issues like below.
any one can you please brief about this below error
%ASR1000_PEM-3-PEMFAIL: The PEM in slot 0 is switched off or encountering a failure condition.
%ASR1000_PEM-6-PEMOK: The PEM in slot 0 is functioning properly
regards,
Kannan
InayathUlla Sharieff
Kannan,
As per the error message decode -
http://www.cisco.com/cgi-bin/Support/Errordecoder/index.cgi?action=searc
h&index=all&locale=en&query=%25ASR1000_PEM-3-PEMFAIL%3A&counter=0&paging
=5&links=reference&sa=Submit
Explaination: The Power Entry Module (PEM) hardware is either switched
off, or is reporting a failure condition due to a possible installation
or power problem, or other hardware failure.
Recommended Action: Following proper safety and grounding guidelines,
verify the installation of the PEM and confirm that the hardware is
fully seated and properly screwed
in. Verify that power is connected and turned on. Verify that the PEM is
turned on.
Action Plan:
Firstly, I would suggest we try the above mentioned recommended action
and verify that power module is inserted correctly.
Do try to reseat the module and check if the messages go away.
In case the messages continue to appear, it would be best to replace the
module (ASR1002-PWR-AC=)
Inayath
*Plz rate all usefull post.
Kannan,
turned on.
Action Plan:
Inayath
