VSS Actions
carl_townshend
Hi all
This morning I rebooted my active VSS switch
switch 2 took the active role and all was OK
Once switch 1 was back up, I failed the supervisor back over to switch 1
I noticed the following output
LOCAL    1     UP      FALSE(N )   150(150)  ACTIVE   0      0
REMOTE   2     UP      FALSE(N )   110(110)  STANDBY  9341   9459
So, its this saying switch 1 is now back as active VSS role?
why has this happened as I thought switch 2 was the active VSS, is it because I did a switch back of the supervisor card to switch 1 ?
Cheers
Carl
InayathUlla Sharieff
Carl,
According to the output of show switch virtual role on this device it means that this switch(SwitchA) is active now.
You can check this with command:show switch virtual --- you will  be able to see the switch operational role.(Active or standby).
Very good info on how the VSS stands on is ref in the link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html
How did you switch the supervisor back to siwtch 1?
Inayath
*Plz rate all usefull posts.
Leo Laohoo
What's the output to the command "sh redundancy"?
Once switch 1 came back online, I did a redundancy force-switchover command
Switch mode                  : Virtual Switch
Virtual switch domain number : 100
Local switch number          : 1
Local switch operational role: Virtual Switch Active
Peer switch number           : 2
Peer switch operational role : Virtual Switch Standby
Current Processor Information :
               Active Location = slot 1/5
        Current Software state = ACTIVE
       Uptime in current state = 50 minutes
                 Image Version = Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI4a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 16-Jul-10 19:51 by prod_rel_team
                          BOOT = sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI4a.bin,1;sup-bootdisk:,1;
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 2/5
        Current Software state = STANDBY HOT
       Uptime in current state = 34 minutes
                          BOOT = sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI4a.bin,12;sup-bootdisk:,1;
The output looks fine.
the switch1 sup is back online.
let us know what else is required on this.
Inayath
