issue with config switch vlan
Getting teh following error on my config for a switch.
00:36:26: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/1 (1), with sw-testlab. dgit.net GigabitEthernet4/0/20 (104).
lab1#show run int vlan 808
Current configuration : 175 bytes
interface Vlan808
ip address 192.168.30.1 255.255.255.0
ip helper-address 10.1.1.72
ip helper-address 10.1.1.73
no ip redirects
no ip proxy-arp
no ip route-cache
end
Cisco Vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/3, Fa0/4, Fa0/5, Fa0/6
                                                Fa0/7, Fa0/8, Fa0/9, Fa0/10
                                                Fa0/11, Fa0/12, Fa0/13, Fa0/14
                                                Fa0/15, Fa0/16, Fa0/17, Fa0/18
                                                Fa0/19, Fa0/20, Fa0/21, Fa0/22
                                                Fa0/23, Fa0/24
11   sh-inside                        active
15   outside                          active
20   dmz                              active
21   sh-dmz                           active
101  servers                          active
103  user_data                        active
104  wifi                             active
808  VLAN0808                         active    Fa0/1, Fa0/2
Cisco version
cisco WS-C2950-24 (RC32300) processor (revision R0) with 19918K bytes of memory.
Processor board ID FOC0911Y02M
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:13:7F:E4:2C:40
Motherboard assembly number: 73-5781-13
Power supply part number: 34-0965-01
Motherboard serial number: FOC09081JAB
Power supply serial number: DAB09083EHY
Model revision number: R0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: FOC0911Y02M
Configuration register is 0xF
7 Replies 7
Daniel McDavid
Can you give a 'show run int fa0/1' on lab1 and 'show run int gi4/0/20' on sw-testlab.dgit.net? It looks like the gig port is configured as a trunk port and the fast ethernet is configured as an access port.
#show run int gi 4/0/20
Building configuration...
Current configuration : 118 bytes
interface GigabitEthernet4/0/20
switchport access vlan 104
switchport voice vlan 204
spanning-tree portfast
end
lab1#show run int fa0/1
Current configuration : 85 bytes
interface FastEthernet0/1
switchport access vlan 808
switchport mode access
end
There is your Native VLAN mismatch. Port fa0/1 is sending VLAN 808 and gi 4/0/20 is sending 104. What are you trying to send between the two switches?
What i would like to do is add this switch in the conference room, and connect it to our existing network. Just basically providing more ports for a room with no ports.
You could just wipe and erase the 2950 and plug it in as it is. That would be 'wr erase' and 'delete vlan.dat', then reload. Make sure you take spanning-tree portfast off of port gi4/0/20. You should probably set up a trunk between the two, though. It would be something like:
! sw-testlab. dgit.net
int gi4/0/20
switchport mode trunk
switchport trunk allowed vlan 104,204, [mgmt vlan]
! lab1
int fa0/1
int range fa0/2 - 24
vlan 104
name data
vlan 204
name voice
What is your management VLAN? 808?
Management vlan is 100
So include that VLAN on your trunks:
! lab1
int fa0/1
switchport trunk allowed vlan add 100
int gi4/0/20
And give the 'lab1' switch an IP address on your management subnet:
! lab1
vlan 100
name mgmt
int vlan 100
ip address [ip address] [subnet mask]
no shut
ip default-gateway [gateway of mgmt subnet]
