Issue with Config
ray_stone
Level 7
Level 7
Hello Experts,
I'm in process of configuring the firewall and switch model 2948G running on CAT OS where I configured sub interfaces and assigned the IP addresses and VLAN on firewall interface and the firewall port is connected with switch port which is a trunk port allowing all the VLAN traffic. Now when I connect any machine with any switch port member of VLAN 1 then I won't able to ping the gateway even I assigned the IP address from the same network of VLAN 1 to switch sc0 port that I can ping so most probably it looks the communication problem in between switch and firewall. The firewall model is asa 5510 with security plus license. Please assist in this and share your thoughts what could be a problem and how to resolve it. I'm not expert in CAT OS and having some problems to troubleshoot the issue.
8 Replies 8
wipronitin
Community Member
Hello Ray,
Ping is not enabled by default on Cisco ASA. Can you try to ping the machine IP from ASA instead.
If that is successful, it means there is no communication issue between the firewall & switch. You would then need to allow ping on your ASA.
Let us know the output.
Thanks.
ray_stone
Level 7
Level 7
Yes I did from both ends but it didn't work.
Hello Ray,
Try to create SVI for VLAN 1 on your switch as well. Then try to ping it from your machine & Firewall. This will confirm if the issue is between the machine & switch or between switch & firewall.
Once done, please share the port configuration for connection from switch to firewall. Also give config for firewall port connected to switch as well.
Thanks.
ray_stone
Level 7
Level 7
All ports other than trunk port are by default are a part of VLAN 1 on switch so no need to configure it separately
I can ping the assigned IP of switch sc0 from connected machine so the problem is only in between firewall and switch communication where I need your assist.
Please share the configuration done on firewall..
Please see the firewall config below which access I have it right now. the switch config I will send it later once my colleague reach at DC as the switch can be accessible via console:
ASA Version 8.2(5)
names
interface Ethernet0/0
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.224
interface Ethernet0/1
no nameif
no security-level
no ip address
interface Ethernet0/2
no nameif
no security-level
no ip address
interface Ethernet0/3
<--- More --->
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
interface Redundant1
member-interface Ethernet0/1
member-interface Ethernet0/2
no nameif
no security-level
no ip address
interface Redundant1.1
description Management
vlan 1
nameif inside
security-level 100
ip address 10.1.10.1 255.255.255.0
<--- More --->
interface Redundant1.2
description DMZ Servers
vlan 2
nameif DMZ
security-level 50
ip address 10.1.12.1 255.255.255.0
interface Redundant1.3
description Infrastructure Servers
vlan 3
nameif Infra
security-level 60
ip address 10.1.14.1 255.255.255.0
interface Redundant1.4
description Database Servers
vlan 4
nameif database
security-level 90
ip address 10.1.16.1 255.255.255.0
boot system disk0:/asa825-k8.bin
ftp mode passive
<--- More --->
access-list dc_splitTunnelAcl standard permit 10.1.10.0 255.255.255.0
access-list dc_splitTunnelAcl standard permit 10.1.16.0 255.255.255.0
access-list dc_splitTunnelAcl standard permit 10.1.12.0 255.255.255.0
access-list dc_splitTunnelAcl standard permit 10.1.14.0 255.255.255.0
access-list inside_nat0_outbound_1 extended permit ip 10.1.10.0 255.255.255.0 192.168.11.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
mtu Infra 1500
mtu database 1500
ip local pool DC_Pool 192.168.11.100-192.168.11.254 mask 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip verify reverse-path interface DMZ
ip verify reverse-path interface Infra
ip verify reverse-path interface database
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
<--- More --->
nat (inside) 0 access-list inside_nat0_outbound_1
route outside 0.0.0.0 0.0.0.0 216.182.216.129 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
<--- More --->
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
management-access inside
threat-detection basic-threat
<--- More --->
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
<--- More --->
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
call-home
<--- More --->
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:ff8c256c0925e4125da7163b1d08a5ba
Logoff
ray_stone
Level 7
Level 7
Can somebody please assist in this?
Please see the switch config as well
#time: Fri Jul 5 2013, 12:54:28
#version 8.4(11)GLX
#dot1x
set feature dot1x-radius-keepalive disable
#system
set system name Switch-Primary
set system location
set system contact
#frame distribution method
set port channel all distribution mac both
#ip
set interface sc0 1 10.1.10.2/255.255.255.0 10.1.10.255
set interface sl0 down
set interface me1 down
set ip route 0.0.0.0/0.0.0.0 10.1.10.1
set ip alias default 0.0.0.0
#set boot command
set boot config-register 0xf
set boot system flash bootflash:cat4000-k9.8-4-11-GLX.bin
#multicast filter
set igmp filter disable
#module 1 : 0-port Switching Supervisor
#module 2 : 50-port 10/100/1000 Ethernet
set trunk 2/12 on dot1q 1-1005,1025-4094
end
Switch-Primary-> (enable)
