Issue with interfaces in VRF
Scott Brien
Level 4
Level 4
We are currently experiencing an issue when we place a sub-if into a VRF.
What we are seeing is when the sub-interface in configured out of the VRF the service works correctly, however when we place the SUB-IF into the vrf the upstream switch doesn't even pick up the mac address of the interface.
Here is some of the configuration we have done for the VRF.
vrf definition vrf1
address-family ipv4
exit-address-family
interface GigabitEthernet0/1/3.701
description Descr
vrf forwarding vrf1
encapsulation dot1Q 701
ip address 1.1.1.1 255.255.255.248
upstream switch:
interface Ethernet1/31
  description **TRUNK **
  switchport mode trunk
  speed 1000
  duplex full
When the vrf forwarding is enabled the mac address is removed from the switches mac table pings drop etc.
Hello Scott,
A stupid question - are you using the vrf keyword in the ping command when pinging from the 1.1.1.1, i.e., ping vrf vrf1 1.1.1.2? If you ping 1.1.1.1 from 1.1.1.2, does it work with the subif in the VRF?
Also, I wonder... when on the 1.1.1.1, can it ping itself? I.e. ping vrf vrf1 1.1.1.1 - does that work? By the way, what switch platform is this?
Best regards,
Peter
Reza Sharifi
Can you add a rd to your vrf and try again?
vrf definition vrf1
rd 1:1
Also, what device is pinging what device (IPs)?
Have added the RD in, no luck.
We are pinging across layer 2 space here so trying to ping 1.1.1.2 from 1.1.1.1.
As i was saying if we remove the VRF configuration the sevice operates correctly.
Scott
Hello Scott,
Best regards,
Peter
Hi Peter,
Now who looks stupid! I was using the sub-if for the source rather than the vrf keyword.
The switch is N5k.
Thanks for your hlep.
Scott
