Issue with Port getting shut
jorge.s
We are having an issue with a port getting shut due to port-security reasons, from a Mac-Address connected in a different switch.
We have the following overall config:
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause unicast-flood
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery interval 600
and on a port by port, we have:
switchport mode access
switchport port-security
switchport port-security aging time 1
switchport port-security aging type inactivity
but when I check the err-disabled detect, I get the following:
STR0073#sh errdisable detect
ErrDisable Reason Detection Mode
arp-inspection Enabled port
bpduguard Enabled port
channel-misconfig Enabled port
community-limit Enabled port
dhcp-rate-limit Enabled port
dtp-flap Enabled port
ekey Enabled port
gbic-invalid Enabled port
invalid-policy Enabled port
l2ptguard Enabled port
link-flap Enabled port
link-monitor-fail Enabled port
loopback Enabled port
lsgroup Enabled port
oam-remote-failur Enabled port
pagp-flap Enabled port
psecure-violation Enabled port/vlan
security-violatio Enabled port
sfp-config-mismat Enabled port
storm-control Enabled port
udld Enabled port
unicast-flood Enabled port
vmps Enabled port
if you see on psecure-violation, the mode is port/vlan, what that means?
Jorge
Edison Ortiz
A secure port can be an access port or a trunk port therefore the errdisable feature is not only tracking a per port violation but also a per vlan violation.
HTH,
__
Edison.
