issue with usb console into 2911 router
carl_townshend
Hi all
I have installed a cisco 2911 router and the cisco usb console drivers on my pc, win 7 64 bit.
however when I use putty and open the com port assigned it just goes blank, I am using the usb port on my laptop to connect and using the cisco usb console cable provided
any ideas ?
Reza Sharifi
After installing the driver on your PC, does you PC recognizes the com port?
start/devices and printer page will show you if the com port is installed correctly.
