ip sla differennces between 2960S vs 3560
lcaruso
Level 6
Level 6
We replaced a 3560 with a new 2960S and I'm only able to configure a single ip sla where before we had three ip sla entries on the 3560.
Obviously, one is a L2 switch and the other a L3 switch. This is an expected difference between switches, correct?
This license is only for lanbase but the image is universalk9. Is that the problem?
No, that is fine.  The image is unversal these day and you just need the correct license level which you already have (IP Base).
6 Replies 6
Reza Sharifi
Is the switch running LAN Base image?
from the config guide:
To use IP SLAs, the switch must be running the LAN Base image.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/15.0_1_se/configuration/guide/2960_scg.pdf
Thanks for your reply. The image running is
System image file is "flash:/c2960s-universalk9-mz.122-58.SE2.bin"
The message I get after defining the first ip sla and then trying to define another is (the first entry is ip sla 11)
switch(config)#ip sla 40000
Entry already running and cannot be modified
        (only can delete (no) and start over)
        (check to see if the probe has finished exiting)
Can you post "sh lice" and "sh ver"?
Switch#sh lic
Index 1 Feature: lanlite
        Period left: 0  minute  0  second
Index 2 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
Switch#sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 02:22 by prod_rel_team
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
Switch uptime is 6 days, 2 hours, 55 minutes
cisco WS-C2960S-48FPS-L (PowerPC) processor (revision E0) with 131072K bytes of memory.
Processor board ID
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       :
Motherboard assembly number     : 73-12547-08
Power supply part number        : 341-0382-02
Motherboard serial number       :
Power supply serial number      :
Model revision number           : E0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48FPS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     :
System serial number            :
Top Assembly Part Number        : 800-32647-03
Top Assembly Revision Number    : A0
Version ID                      : V03
CLEI Code Number                : COMGB00ARC
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48FPS-L  12.2(58)SE2           C2960S-UNIVERSALK9-M
Configuration register is 0xF
This troubleshooting sequence.
Does the sla on the far end cause this switch to think it is still running when it doesn't exist on this switch?
Switch(config)#ip sla 40000
Switch(config)#no ip sla 40000
% Failed to post event to delete operation 40000
Switch(config)#ip sla reset
This will remove all configured operations, continue? [n] y
