Issues Pinging Switch
nohara
Visitor
I am having issues pinging a switch that is directly connected to the switch I am currently plugged into. My laptop is plugged into Gi0/3 on Switch1 with an IP of 10.0.100.50/24 and a gateway of 10.0.100.1. I am able to ping the SVI for VLAN 100 and VLAN 99 however, I am unable to ping 10.0.99.2. When consoled into Switch1 I am able to ping 10.0.99.2. Is there a reason why I am unable to ping 10.0.99.2 from my laptop?
Switch1#
interface Port-channel1
description <--Trunk to Switch2-->
switchport trunk native vlan 99
switchport trunk allowed vlan 99,100
switchport mode trunk
interface GigabitEthernet0/1
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet0/2
interface GigabitEthernet0/3
switchport access vlan 100
switchport mode access
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 10.0.99.1 255.255.255.0
interface Vlan100
ip address 10.0.100.1 255.255.255.0
Switch2#
description <--Trunk to Switch1-->
interface FastEthernet0/1
interface FastEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan99
ip address 10.0.99.2 255.255.255.0
ip default-gateway 10.0.99.1
Julio E. Moisa
Try to remove this command line switchport trunk native vlan 99, also verify with a: show interface status if the SVI are up up.
Usually the native vlan is not associated to any IP address or SVI.
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Jon Marshall
What model switch is switch2 ?
Jon
Julio E. Moisa
Regards.
Ok, by removing "switchport trunk native vlan 99" from both po1 interfaces it worked.
Yes, actually the native vlan should not be associated to any ip address, also the frames are untagged over the trunks.
