Issues with deploying 6880-X in VSS Mode
rpatnaik_slf
Hi Everyone,
I wanted to query the support community to see if folks are encountering issues in deploying the 6880-X in VSS mode.  We first looked at this soluition when it was running 15.1(2) SY2 as the recommened GA code.  We ran into several issues:
1) VSL Link Timeout - Workaround:modify LMP timer or upgrade to 15.1(2)SY4
2) Port-member goes into suspendstate when using 1000BASE-SX - shut/no shut suspended interface
We ran into this and some other issues even with the eFSU upgrade process.  So my question is have you run into similiar difficulties in running the 6880 in VSS mode.  Did you go ahead and deploy?  If so did you deploy with 15.1(2)SY4 (new Cisco GA code) or did you live with the state you are in?
Were there ways that you mitigated these issues?
Patnaik
lenperez
Hello friend,
Coudl you please share with us more information about the errors you are facing with?
It could help if you can post the logs seen so we can have more details and the best solution for the issue.
At this moment, I can tell you tha VSL Link Timeout issue is fixed in 15.1(2)SY4 -> CSCup99867 bug
The 15.1(2) SY2 version is not fixed, this is why you are getting timeout errors. About the others, please share more details.
Best Regards,  :D
Hi Lenperez,
I am now running 15.1(2)SY4.  In our lab environment we are running GLT-C 1GE optics.  When I perform a redundancy force-switchover or power cycle the active switch (aka control-plane switch) I see the following error in the logs.
Jan 14 15:53:46 est: %EC-SW1_STBY-5-CANNOT_BUNDLE2: Te2/5/14 is not compatible with Te1/3/14 and will be suspended (speed of Te2/5/14 is 1000M, Te1/3/14 is 10G)
As you can see switch 1's optic is being recognized as a 10GE interface.  The LACP bundle won't come up with two different bandwidth speeds.  It seems to be an negotiation issue.
In our production trial, we saw a similar issue using 1000BASE-SX (GLC-SX-MM) fibre optics.  The port comes up in suspended mode.  This time there is no indication of speed mismatch.  We needed to shut/no shut the suspended member or shut/no shut the port-channel.
Some of the other issues I have run into are the IA - instant access upgrades. A fix is now there but you need a minimum combination of EX6 microcode and SY3 or SY4.
There seems to be too many small issues.  Just wondering what your thoughts are on the product line.
Cheers,
R
Can you post the config for interfaces Te2/5/14 and Te1/3/14?
Also, can you post the Portchannel config?
Hi Reza,
Here you go.  Just so you know I resolved the suspended port-member by OIR the optic that was displayed as a 10G interface.
lab6880#sh run inter te1/3/14
Building configuration...
Current configuration : 1546 bytes
interface TenGigabitEthernet1/3/14
 no switchport
 mtu 9216
 no ip address
 no ip proxy-arp
 platform qos queue-mode mode-dscp
 wrr-queue bandwidth 100 150 125 150 0 0 100
 wrr-queue queue-limit 20 40 10 10 0 0 5
 wrr-queue random-detect min-threshold 1 50 60 80 100
 wrr-queue random-detect min-threshold 2 70 100 100 100
 wrr-queue random-detect min-threshold 3 70 100 100 100
 wrr-queue cos-map 4 1 3
 wrr-queue cos-map 5 1 4
 wrr-queue dscp-map 1 1 1 2 3 4 5 6 7 8
 wrr-queue dscp-map 1 1 9 11 13 15 16 17 19 21
 wrr-queue dscp-map 1 1 23 25 27 29 31 33 35 37
 wrr-queue dscp-map 1 1 39 41 42 43 44 45 47 49
 wrr-queue dscp-map 1 1 50 51 52 53 54 55 57 58
 wrr-queue dscp-map 1 1 59 60 61 62 63
 wrr-queue dscp-map 1 2 0
 wrr-queue dscp-map 2 1 10 12 14
 wrr-queue dscp-map 3 1 18 20 22
 wrr-queue dscp-map 3 2 26 28 30
 wrr-queue dscp-map 4 1 24 32 34 36 38
 wrr-queue dscp-map 7 1 48 56
 rcv-queue dscp-map 1 1 1 2 3 4 5 6 7 8
 rcv-queue dscp-map 1 1 9 11 13 15 17 19 21 23
 rcv-queue dscp-map 1 1 25 27 29 31 33 35 37 39
 rcv-queue dscp-map 1 1 41 42 43 44 45 47 49 50
 rcv-queue dscp-map 1 1 51 52 53 54 55 57 58 59
 rcv-queue dscp-map 1 1 60 61 62 63
 rcv-queue dscp-map 1 2 0
 rcv-queue dscp-map 1 3 16
 rcv-queue dscp-map 2 1 10 12 14
 rcv-queue dscp-map 3 1 18 20 22
 rcv-queue dscp-map 3 2 26 28 30
 rcv-queue dscp-map 4 1 24 32 34 36 38
 rcv-queue dscp-map 7 1 48 56
 macro description UPLINK
 arp timeout 300
 channel-group 100 mode active
end
lab6880#sh run inter te2/5/14
interface TenGigabitEthernet2/5/14
 no switchport
 mtu 9216
 no ip address
 no ip proxy-arp
 arp timeout 300
end
interface Port-channel100
 no switchport
 dampening 20
 mtu 9216
 ip address 172.16.2.250 255.255.255.254
 ip pim sparse-dense-mode
 ip ospf network point-to-point
 logging event link-status
 logging event nfas-status
 logging event bundle-status
 load-interval 30
 carrier-delay msec 0
