Issues with FWSM and 6509: heartbeat drop?
j-pickering
We have a couple of 6509s with the firewall module (WS-SVC-FWM-1) in them.  There is a redundant link between the switches and the firewalls are set for active/passive. They're set up like this with 2 Nexus 5ks behind them:
Last night the network failed behind the 6500s.  The only errors we received on the 6500:
Aug 15 19:16:28.002 AWST: %SEC-6-IPACCESSLOGDP: list restrict-UPS-SC denied icmp 172.16.200.1 -> 172.16.40.179 (0/0), 1 packet
Aug 15 19:16:49.510 AWST: %SEC-6-IPACCESSLOGDP: list restrict-UPS-SC denied icmp 172.16.200.22 -> 172.16.40.29 (0/0), 1 packet
Aug 15 19:23:08.540 AWST: %SVCLC-5-FWTRUNK: Firewalled VLANs configured on trunks
Aug 15 19:23:08.652 AWST: %SVCLC-SW2_STBY-5-FWTRUNK: Firewalled VLANs configured on trunks
Aug 15 20:00:58.425 AWST: %SEC-6-IPACCESSLOGDP: list restrict-UPS-SC denied icmp 172.16.205.2 -> 172.16.40.16 (0/0), 1 packet
Aug 15 20:44:01.010 AWST: %SEC-6-IPACCESSLOGDP: list restrict-UPS-SC denied icmp 172.16.200.10 -> 172.16.40.192 (0/0), 1 packet
And on the firewall modules:
/InternalFW/act# sh logg
Syslog logging: enabled
    Facility: 22
    Timestamp logging: enabled
    Name logging: enabled
    Standby logging: disabled
    Deny Conn when Queue Full: disabled
    Console logging: level errors, class auth, 1514 messages logged
    Monitor logging: level emergencies, 367 messages logged
    Buffer logging: level errors, 1514 messages logged
    Trap logging: level informational, facility 22, 73537453 messages logged
        Logging to Outside Tftptest errors: 418252  dropped: 72682199
    History logging: level warnings, 369290 messages logged
    Device ID: disabled
    Mail logging: disabled
    ASDM logging: level notifications, 370960 messages logged
on interface Shield-B2C
Aug 15 2012 22:26:36: %FWSM-1-105008: (Primary) Testing Interface CIM-Inside
Aug 15 2012 22:26:36: %FWSM-1-105008: (Primary) Testing Interface Shield-B2C
Aug 15 2012 22:26:37: %FWSM-1-105009: (Primary) Testing on interface CIM-Inside Passed
Aug 15 2012 22:26:42: %FWSM-1-105009: (Primary) Testing on interface Shield-B2C Passed
Aug 15 2012 22:26:51: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface Shield-Inside
Aug 15 2012 22:26:51: %FWSM-1-105008: (Primary) Testing Interface Shield-Inside
Aug 15 2012 22:26:51: %FWSM-1-105009: (Primary) Testing on interface Shield-Inside Passed
Aug 15 2012 22:27:51: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface BWS-Inside
Aug 15 2012 22:27:51: %FWSM-1-105008: (Primary) Testing Interface BWS-Inside
Aug 15 2012 22:27:52: %FWSM-1-105009: (Primary) Testing on interface BWS-Inside Passed
Aug 15 2012 22:28:06: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface CIM-Inside
Aug 15 2012 22:28:06: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface Shield-B2C
Aug 15 2012 22:28:06: %FWSM-1-105008: (Primary) Testing Interface CIM-Inside
Aug 15 2012 22:28:06: %FWSM-1-105008: (Primary) Testing Interface Shield-B2C
Aug 15 2012 22:28:07: %FWSM-1-105009: (Primary) Testing on interface Shield-B2C Passed
Aug 15 2012 22:28:09: %FWSM-1-105009: (Primary) Testing on interface CIM-Inside Passed
Aug 15 2012 22:28:36: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface Shield-Inside
Aug 15 2012 22:28:36: %FWSM-1-105008: (Primary) Testing Interface Shield-Inside
Aug 15 2012 22:28:36: %FWSM-1-105009: (Primary) Testing on interface Shield-Inside Passed
Aug 15 2012 22:29:21: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface BWS-Inside
Aug 15 2012 22:29:21: %FWSM-1-105008: (Primary) Testing Interface BWS-Inside
Aug 15 2012 22:29:22: %FWSM-1-105009: (Primary) Testing on interface BWS-Inside Passed
Aug 15 2012 22:29:36: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface CIM-Inside
Aug 15 2012 22:29:36: %FWSM-1-105008: (Primary) Testing Interface CIM-Inside
Aug 15 2012 22:29:40: %FWSM-1-105009: (Primary) Testing on interface CIM-Inside Passed
Aug 15 2012 22:29:51: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface Shield-B2C
Aug 15 2012 22:29:51: %FWSM-1-105008: (Primary) Testing Interface Shield-B2C
Aug 15 2012 22:29:52: %FWSM-1-105009: (Primary) Testing on interface Shield-B2C Passed
Aug 15 2012 22:30:06: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface Shield-Inside
Aug 15 2012 22:30:06: %FWSM-1-105008: (Primary) Testing Interface Shield-Inside
Aug 15 2012 22:30:06: %FWSM-1-105009: (Primary) Testing on interface Shield-Inside Passed
Aug 15 2012 22:31:06: %FWSM-1-105005: (Primary) Lost Failover communications with mate on interface BWS-Inside
Aug 15 2012 22:31:06: %FWSM-1-105008: (Primary) Testing Interface BWS-Inside
No one had logged in to make a change on the switches or FW modules at the time and there is no evidence of the line going down.
Currently the seconardy FW module is powered down.  Any ideas what to look for before we power it back up?
The issue is similar to this old thread:
https://supportforums.cisco.com/docs/DOC-4831
Ton V Engelen
Level 3
Level 3
it seems like this fwsm lost contact with its fail-over fwsm peer.
You say the network behind the 6500 failed. Could it be that the FWSM's lost contact because of this? Some routes disappeared or something?
In that case, if that network is up and running again, they should be able to see each other again.
I woud only worry about what happens when they see each other again.(who will become master) cause i do not know the active/standby configuration of your set up.
Maybe that does not matter in your set up. (it would matter in my setuop, i m running active active over 2 locations...)
