Issues with pinging high numbered vlan on cisco catalyst 3750 PoE-48
vesiclife1
I have a Cisco switch that has a couple VLAN's, VLAN 10, 50 and VLAN 1000. The previous two can be pinged but I am unable to ping VLAN 1000. I am not sure if it is the numbering scheme that is the issue or if I have to go digging some more to solve the problem.
10 Replies 10
Hello friend,
i think vlan 1000 should not be a problem. Could you please share the specific vlan configuration and switch port config for vlan1000 on which you have connected your testing device
I just assume that your config also looks like this
vlan 1000
name xxxx
int vlan 1000
ip add
And switch config for the testing device
int gi0/2
switchport mode access
switchport access vlan 1000
if this is the config I think it should work without any issues
thanks
Switch1#show vlan
VLAN  Name                        Status           Ports
1000    VLAN1000               Active            Fa1/0/5, Fa1/0/7, Fa1/0/8,
        Fa1/0/9, Fa1/0/12, Fa1/0/13
     Fa1/0/14, Fa1/0/15, Fa1/16
     Fa1/0/17, Fa1/0/18, Fa1/0/19
     Fa1/0/20, Fa1/0/21, Fa1/0/22
     Fa1/0/23, Fa1/0/24
VLAN      Type    SAID             MTU    Parent  RingNo   BridgeNo  Trans1 Trans2
1000        enet      101000       1500         _            _            _              0         0
Remote SPAN VLAN
Disabled
we basically are pinging from the computers hooked up to the switch by CAT5 which are accessing the backend of a server.
vlan 10 ip address 192.168.1.200
vlan 50 ip address 192.168.5.200
vlan 1000 ip address 192.168.0.200
all with a subnet mask of 255.255.255.0
are you able to ping gateway vlan 1000 gateway ip from vlan 1000 ?
please provide the below outputs
show ver
show run int gig0/1 (access ports from vlan 1000)
and check are you learning the MAC address on the vlan 1000
Do you have only one vlan configured on the switch ? On which vlan the backend server is connected ?
All the vlan's are connect through one LAN on the server using a Hyper V vswitch. I can ping the gateway ip 192.168.0.1 no problem.
VLAN 1000
show ver
Cisco IOS Software, C3750 software (C3750-IPSERVICESK9-M), Version 12.2 (55) SE3, RELEASE SOFTWARE (fc1)
The access ports are 5, 8, 7, 9,12 - 24 for vlan 1000
