Issues with port-channel not passing traffic in a L2 ring
chad-young
Hi all!  First time poster, so please be gentle.  My thanks in advance to anyone who can assist.
Anyway, here goes.  I have three sites, all of which hosts various VLANs for multiple kinds of hosts.  A previous tech had set up a trio of L2 switches in a ring and trunked all the active VLANs on the three switches to each other.  The idea was to be able to connect to the VLANs at any of the three sites and have a redundant L2 path between all the sites.  I upgraded one leg to an etherchannel combining two ports into a single 2Gbps pipeline thhrough a Canary CCN-2000 CWDM multiplexer. All links are up, all trunks are up, and the port-channel is up.
Here is the issue - that I can tell, traffic from Site A to Site C is almost entireley *not* going over the faster etherchannel.  It is choosing the slower path through Site B.  AFAIK, spanning tree seems to see the A-C trunk and assigns it a lower cost, but, as far as I can tell, nearly all the traffic is all going taking the other connection.  I admit, though, that my STP-fu is not strong.
I suspect traffic taking the A->B->C path may been the case for a while.  I only noticed it today when adding VLAN 3012 to the trunk.  I made a typo and brought the A->C port-channel down briefly and nothing lost connectivity.  The previous tech noted that when the Site B switch was rebooted last year, traffic did not appear to revert to the A->C direct path.
Am I missing something here?  What do you think might be going on?
http://i91.photobucket.com/albums/k316/caloos2000/trunkedringissue.jpg
Site A to site C trunk config:
Side A Switch:
interface Port-channel1
switchport trunk allowed vlan 22,27,33,35,46,49,70,91,95,97-99,101,253,400,777
switchport trunk allowed vlan add 1099,1100,2001,2002,3012
switchport mode trunk
interface GigabitEthernet0/47
description Ring Trunks CDC
no cdp enable
channel-group 1 mode on
interface GigabitEthernet0/48
no cdp enable
Site C Switch:
description Ring Trunks Admin
From site C Switch:
Cleared counters, waited a few minutes and then:
SiteC#sh int port-channel 1
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 000a.b841.ddb0 (bia 000a.b841.ddb0)
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Members in this channel: Gi0/47 Gi0/48
  Last input never, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:01:23
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 58000 bits/sec, 45 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     3724 packets output, 596017 bytes, 0 underruns
SiteC#sh int port-channel 1 trunk
Port        Mode             Encapsulation  Status        Native vlan
Po1         on               802.1q         trunking      1
Port        Vlans allowed on trunk
Po1         22,27,33,35,46,49,70,91,95,97-99,101,253,400,777,1099-1100,2001-2002
Port        Vlans allowed and active in management domain
Po1         27,33,35,46,49,70,91,95,97-99,101,400,777,1099-1100,2001-2002
Port        Vlans in spanning tree forwarding state and not pruned
If the MUX's are ok then you might want to check your SFP's as well. The issue could very well be at your end too
Kishore
14 Replies 14
samavedula_rama
Hi Chad...Happy Friday.
I know this is kinda dumb but did you already add a test vlan just between A and C [on the port-channel] and try pinging ? Just want to make sure there isn't an issue with port-channel itself.
Also, just pick a vlan in the ring and post  "sh spanning-tree vlan " output.
Thanks.
Atif Awan
You need to understand your Layer-2 topology to be able to get an idea of why traffic is not taking the desired path. A good point to start will be to determine what your root bridge for a VLAN is (assuming you are running a PVST variant). Take a couple of sample VLANs and map their Layer-2 topology using the 'show spanning-tree' commands. Once you have that I am sure you will understand what is going on; may be the root switch needs to be manually enforced. If you still need assistance do share the relevant command outputs with us for one or two VLANs.
Atif
glen.grant
  Was spanning tree roots ever defined for all these vlans ?   Also I would look to see which port is blocked on what switch as in this design it  has a built in loop for all vlans so it has to block one of the ports in the design so all traffic for a given vlan can only flow one way depending on what port is blocking for that vlan  as cisco uses per vlan spanning tree .
chad-young
Ok, got the spanning-tree infor for two VLANs from the Site A Switch:
SiteA#sh spanning-tree vlan 27
VLAN0027
  Spanning tree enabled protocol ieee
  Root ID    Priority    32768
             Address     0014.2285.fee3
             Cost        8
             Port        2 (GigabitEthernet0/2)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32795  (priority 32768 sys-id-ext 27)
             Address     000a.b841.e200
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/2               Root FWD 4         128.2    P2p
Gi0/46              Desg FWD 4         128.46   P2p
Po1                 Desg FWD 3         128.56   P2p
SiteA#sh spanning-tree vlan 35
VLAN0035
             Address     0012.a9ef.8960
             Cost        16
             Port        46 (GigabitEthernet0/46)
  Bridge ID  Priority    32803  (priority 32768 sys-id-ext 35)
             Aging Time  300 sec
Gi0/46              Root FWD 4         128.46   P2p
When I get back in the office later next week, I will create a test VLAN with IP addresses (none of the VLANs have IP addresses except one mgmt VLAN) and try to ping across the Port-channel link.
VLAN0027
             Cost        8
             Aging Time  300 sec
VLAN0035
             Cost        16
             Aging Time  300 sec
VLAN 27 seems to be a local Site-A VLAN as the root port is not one of your uplinks. For VLAN 35 my guess is that The switch in Site B is the root switch. If that is the case then Site C will probably have it's port-channel port blocking for this VLAN. Like I said in my previous post you need to map the complete Layer-2 topology for one or two VLANs and only then will you be able to appreciate what is going on. I am leaning towards incorrect root bridge mapping here as the cause of sub-optimal traffic flow but you need to execute the spanning-tree command on each of the three switches to map the Layer-2 topology for the VLAN.
Atif
chad-young
First off, thanks again.
I think I see where you folks are headed and makes sense.  My lack of STP knowledge is hindering me a bit, but I will do some reading over the weekend on the matter.
That said, I tracked one high-use VLAN with hosts at Site A and Site C and mapped out the VLAN and discovered that Site B was claiming root bridge for this VLAN:
Site A:
VLAN0091
  Root ID    Priority    32859
             Address     000a.b825.a700
             Cost        4
  Bridge ID  Priority    32859  (priority 32768 sys-id-ext 91)
             Aging Time  300 sec
Gi0/18              Desg FWD 4         128.18   P2p
Gi0/20              Desg FWD 4         128.20   P2p
Gi0/21              Desg FWD 4         128.21   P2p
Gi0/22              Desg FWD 4         128.22   P2p
Gi0/23              Desg FWD 19        128.23   P2p
Gi0/25              Desg FWD 4         128.25   P2p
Gi0/28              Desg FWD 4         128.28   P2p
Gi0/29              Desg FWD 4         128.29   P2p
Gi0/30              Desg FWD 4         128.30   P2p
Site B:
VLAN0091
             This bridge is the root
             Aging Time  300 sec
Gi0/23              Desg FWD 4         128.23   P2p
Gi0/24              Desg FWD 4         128.24   P2p
Site C:
VLAN0091
             Cost        4
             Port        45 (GigabitEthernet0/45)
             Address     000a.b841.dd80
             Aging Time  300 sec
Gi0/18              Desg FWD 19        128.18   P2p
Gi0/27              Desg FWD 19        128.27   P2p
Gi0/31              Desg FWD 4         128.31   P2p
Gi0/32              Desg FWD 4         128.32   P2p
Gi0/37              Desg FWD 4         128.37   P2p
Gi0/45              Root FWD 4         128.45   P2p
So, question is, how do I fix this?
Before we fix this I see something strange here. I would have expected either the switch at Site-A or switch at Site-C to put one of it's ports in blocking for this VLAN but this is not the case. Can you please post 'show spanning-tree vlan 91 detail' from both switch-A and switch-C? The output might be long so just attach it as a text file.
Atif
File attached for VLAN 91 on Site C and Site A.
Chad,
There appears to be a communicatoin issue over the port-channel interface. Both switches claim not to receive any BPDUs over this interface.
From Switch-A:
Port 56 (Port-channel1) of VLAN0091 is designated forwarding
   Port path cost 3, Port priority 128, Port Identifier 128.56.
   Designated root has priority 32859, address 000a.b825.a700
   Designated bridge has priority 32859, address 000a.b841.e200
   Designated port id is 128.56, designated path cost 4
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   Link type is point-to-point by default
  BPDU: sent 50101, received 0
From Switch-C:
   Designated bridge has priority 32859, address 000a.b841.dd80
   BPDU: sent 10190452, received 0
There should be a non-zero value in the received field on both switches. I would like you to verify forwarding on both member links first before you make any changes to alter the root bridge.
Atif
Looks like an issue with the media converter. If they are fiber ports, try doing a speed nonegotiate.
If they are not, try hard-coding speed & Duplex settings.
chad-young
Based on some other issues with that MUX, I suspect you may be right and it is the culprit.  I will have to schedule some down time and test further.  I might have to use another fiber path and bypass that MUX entirely.
Thanks!  I will update when I get through with testing.  It may be a few weeks.
Kishore
Well, the connections from Site A to Site C are regular copper Gbit on the switch, then get converted to fiber in the Mux, then back to Copper on the other end.  Ergo, no sfps on that connection.
chad-young
Hi all!  I am going to mark this as resolved now.  The Mux is definitely not behaving, so we are going to switch that to a SM fiber pathway and simplify things a bit.
Thank you everyone for your kind assistance.
