unable to connecting two switches on different network
jawad.hussain
I am linking two different network layer 3 switches, I have made "ip routing" to link different vlans.
the ports connecting two switches i made to work as trunk, also tried to make same vlans on both switches and added the connecting port to same vlan but unable to ping them.
when I run cdp neibhours, it shows switch with domain name but no more details shown.Below are highlights of configuration..
DSL_Swtich#ping 150.1.3.1 (another switch 3650)
Sending 5, 100-byte ICMP Echos to 150.1.3.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
DSL_Swtich#
DSL_Swtich#
Success rate is 0 percent (0/4)
DSL_Swtich#show cdp nei
DSL_Swtich#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
Manar_HQ.manarhq.com
Gig 1/0/47 138 R S I WS-C3650- Gig 2/0/28
SERVER-SW Gig 1/0/46 128 S I WS-C2960X Gig 1/0/44
DSL_Swtich#
another switch side is :
pinging server switch
Kindly assist what show i make configuration to connect both swtich ping each other..
regards
Jawad
2 Accepted Solutions
Hello
As I have stated previously you need to make some changes to you current setup to make this work correctly.
Note..the assumption here is all subnets are /24 address ranges
Sw1
int x/x
Description ports link connecting switch2
swutchport mode access
switchport access vlan 70
ip route 192.168.10.0 .255.255.255.0 vlan 70 150.1.3.1
ip route 192.168.20.0 .255.255.255.0 vlan 70 150.1.3.1
ip route 192.168.30.0 .255.255.255.0 vlan 70 150.1.3.1
ip route 192.168.40.0 .255.255.255.0 vlan 70 150.1.3.1
ip route 192.168.50.0 .255.255.255.0 vlan 70 150.1.3.1
ip route 192.168.60.0 .255.255.255.0 vlan 70 150.1.3.1
ip route 192.168.1.0 .255.255.255.0 vlan 70 150.1.3.1
Sw2
int x/x
Description ports link connecting switch 1
ip route 172.16.0.0 .255.255.255.0 vlan 70 150.1.3.2
ip route 192.168.100.0 .255.255.255.0 vlan 70 150.1.3.2
ip route 192.168.200.0 .255.255.255.0 vlan 70 150.1.3.2
ip route 192.168.250.0 .255.255.255.0 vlan 70 150.1.3.2
Lastly you need your pc and server to have ip addressing allocated to them from any of the vlans that reside on the switch they are connected with the correct subnet masks and default gateways of the L3 interface of the vlan its assigned to as presently they dont relate to any vlan you have defined
Kind Regards
Paul
I am thankful to all of you.
I want to add some info for the future visitor that:
1. I make manual route to 2nd network by adding route add in PC/Server to 150.1.x.x
2. If I make route from switch to switch for whole network it will create traffic load as many clients don't need to forward on another network. ( to save unsual network traffic)
It means the network was approx ready remaining routing between VLANS...
I am again thankful to everyone.....
15 Replies 15
post the full configurations of both switches...
both of the below should work:
3650_1
ip routing
interface GigabitEthernet0/0
switchport mode access
switchport access vlan 150
spanning-tree portfast
interface Vlan150
ip address 150.1.3.1 255.255.255.0
3650_2
ip routing
interface Vlan150
ip address 150.1.3.2 255.255.255.0
3650_1
ip routing
switchport mode trunk
spanning-tree portfast edge
interface Vlan150
3650_2
ip routing
interface Vlan150
dear @Georg Pauwen .
the subnet you mentioned we r not using i.e 255.255.255.0, we are on /16 subnet 255.255.0.0
the second thing is I have made the same configuration both are trunk and in same vlans.spanning tree i did not make.
Ip routing is also working on both sides.
what is the reason if i run spanning tree?
tell me the commands for which u need the configurations?
thanks in advance..
is this a lab or are these real switches ? Typically for a switch to switch connection, you would need a cross cable...
Hello
This is true for very old switches, but for a long time mosts switch have been MDIX compatible so a straight through cable should work fine with the switches noticing the cable pins and change accordingly
Kind Regards
Paul
Martin L
what do u have  configured on SVI ? 150.1.3.1 should be set on SVI interface, like interface vlan x ip add 150.1.3.1 xxxx no shut
the other side should have SVI in the same vlan X, and both SVI must be UP UP.
vlan x should be in database and be allowed on the trunk
check SVIs , check trunks allow vlan x, check vlan database foir vlan x
Dear @Martin L
Both svi's are working and interface and protocol are up..
Trunks are allowed on both ports and vlan are same too.
In VLAN database both are showing fine..
Hello
You still need to tell each switch(router) how to get to the other vlans (subnets), either via and IGP or static routes and they must be sharing a common subnet for connectivity.
Example:
Sw1
interface Vlan3
ip address 3.3.3.3 255.255.255.0
interface Vlan5
ip address 5.5.5.5 255.255.255.0
interface Vlan12
ip address 10.1.12.1 255.255.255.0
ip route 2.2.2.0 255.255.255.0 Vlan12 10.1.12.2
ip route 4.4.4.0 255.255.255.0 Vlan12 10.1.12.2
vlan3,5,12
interface FastEthernet0/19
description link to sw2
switchport access vlan 12
Sw2
interface Vlan2
ip address 2.2.2.254 255.255.255.0
interface Vlan4
ip address 4.4.4.254 255.255.255.0
interface Vlan12
ip address 10.1.12.2 255.255.255.0
ip route 3.3.3.0 255.255.255.0 Vlan12 10.1.12.1
ip route 5.5.5.0 255.255.255.0 Vlan12 10.1.12.1
vlan2,4,12
description link to sw1
Kind Regards
Paul
Dear @paul driver
Did you mean to say IP Default gateway on both sides
i cant make this because ISP routers are connected on these switches and i m afraid if internet will stop,,
Hello
No ,you will have ip routing enabled on both switches.
The two switchs will have common vlan shared between them - in my example its vlan 12 and then the port interconnecting the two switchs will be an access port in vlan 12.
The on either switch you will have the l2/l3 vlans again in my example :
Sw1 - vlan 3-5
Sw2 - vlan 2-4
Lastly you will to populate the routing tables of both switches to allow bidirectional communication, in my example i have used static routes pointing to the share vlan which is vlan 12
Sw1
ip route 2.2.2.0 255.255.255.0 vlan 12 10.1.12.2
ip route 4.4.4.0 255.255.255.0 vlan 12 10.1.12.2
Sw2
ip route 3.3.3.0 255.255.255.0 vlan 12 10.1.12.1
ip route 5.5.5.0 255.255.255.0 vlan 12 10.1.12.1
Thats it...
Kind Regards
Paul
How will be the command i should run on switches
NOTE: I am working on physical switches and both support AUTO MDIX..
network 1
vlan 172   IP address 172.16.0.53 255.255.0.0  (Local Network)
vlan 70     IP address 150.1.3.2 255.255.0.0 (remote network)
port for remote network is trunk and included in vlan 70
network 2
vlan 70    IP address 150.1.3.1 255.255.0.0 (on another network using as SVI)
both ips are working and pinging now
from DSL_Switch i can ping all ip's on another network 150's ip but from client side i cant even ping swtich's SVI ip?
if you need configuration i can provide. tell me what info you need more..
also assist how i will make ip route between these network?
best regards
Hello
FYI- the example I provided was for two switchs physically interconnected between each other both with ip routing and different l3 subnets
Just so no confusion is being made here - Can you post the topology of you network and the current configuration of both switches please.
Kind Regards
Paul
hello, below are details of both network
Network 1
Network 2
Vlan 150 is not in use and nothing is associated with that LAN.
Topology
I can ping from switch to switch any ip but from client to switch or client to another remote client is unsuccessful.
Hello
Sw1
int x/x
Sw2
int x/x
Kind Regards
Paul
