Issues with stacking 2x3850s.
inderjit21
Had issues with upgrade 2x3850 in a stack . Disconnected the stacking cable and was able to upgrade IOS individually. Now when I connect them again with stack cables it not forming the stack.One switch will boot but other is just rebooting giving error.
Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [Cable Auth Failed]
get_local: failed: No such file or directory
I have disconnected/reconnected stacking cable twice( brand new cables).
Both switches have same load and ipservices.
8 Replies 8
Philip D'Ath
Which software version are you now running?  Did you use the "software install" command to do the upgrade?
When re-adding the second switch did you try powering it down, and then back up again?
Upgraded to 03.06.03E   from 03.02.03 . Yes did software install. Yes connecting stacking cables after shutting down both the switches.
Ok, yucky.
Try this:
redundancy
main-cpu
standby console enable
If that doesn't work, backup the config, wipe the second switch, power cycle, and try re-joining it to the stack again.
mlaforest
Was there a resolution to this?  I am experiencing the same issue.
In my case this was a faulty stack cable.
The reason why this may occur during a software upgrade is,
that the switches in stack issue a "cable auth" process, checking if the cable is a valid and original cisco cable. If this fails, it causes a reboot / boot loop...
Same.  Cables were faulty.  RMA'd them and the new ones work perfectly.
hgans
same issue here during upgrade to 3.6.4E
FIPS(NGWC): Flash Key Check : Begin
FIPS(NGWC): Flash Key Check : End, Not Found, FIPS Mode Not Enabled
Jun 9 05:21:31 %STACKMGR-1-RELOAD: Reloading due to reason Cable Auth Failed
Jun 9 05:21:31 %IOSXE-3-PLATFORM: process sysmgr: Reset/Reload requested by [stack-manager].
<Thu Jun 9 05:21:31 2016> Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [Cable Auth Failed]
boot loop since then....
