11-15-2022 06:35 AM
I am hoping someone with enough time and patience will be able to help me with this problem I am having.
My topology is as follows:
Have UniFi AP connected to UniFi switch -> also from that switch (US-8-150W) I have connection to Cisco SG300 switch, -> and from that switch connection goes to Meraki MX64 firtewall appliance.
Now on UniFi controller, I have configured VLAN 55 Guest network with VLAN ID 55 (192.168.55.0/24), and assigne this network to WiFi Guest Public network. All ports on all UniFi devices are set to "ALL" profile, passing packets for all VLANS (I have default VLAN 192.168.1.0/24). On SG300 I have 2 VLANs created VLAN 1 and VLAN 55. All ports on Cisco switch are set as "trunk", untagged for default VLAN and tagged for VLAN55. On Meraki I have 2 VLANS set, 1 and 55, and all ports set to "ALL" profile. I have DHCP enabled for VLAN 55 on Meraki, and problem is when user connects to public guest WiFi, connected device resolves to APIPA IP, not getting IP from DHCP. Cisco SG300 is in Layer2 mode. Additional screenshots attached, so I hope someone can help. Thank you!
