jitter mibs not working
dariarossi1975
I’ve a problem with SNMP jitter Mib on cisco IE4000. The CISCO-IPSLA-JITTER-MIB and CISCO-RTTMON-MIB can’t be read while other mibs are working correctly. This is the configuration of the sitwch:
ip sla 5
udp-jitter 10.10.10.1 5000
 frequency 30
snmp-server community public RO
The responder switch is configured with:
ip sla responder
The same configuration on a C9300-24S works correctly.
Any idea about the problem?
Daria
dariarossi1975
hello,
any idea?
tnks
do you have the responder configured as:
--> ip sla responder udp-echo 10.10.10.1 5000
the responder is configured  with  ip sla responder udp-echo 10.10.10.1 5000.
I've search under https://cfnng.cisco.com/mibs the correct mib and for IE4000 ie4000-universalk9-mz.152-8.E1.bin can 't find any MIB to download. Is it possible?
