Nexus 5672UP input/output errors increasing
zizou6500
Level 3
Level 3
Hi Community,
I'm running into an issue with a 5k switch for several days, I'm getting input/output errors on the uplink ports.
There is mainly 1 uplink port going to the edge device + 1 uplink port going to the peer 5k switch + 4 uplinks going to the FEX devices (N2k).
I already started with changing cable, SFP, and moving ports. However, this didn't help at all.
Can anyone help in this case, please?
8 Replies 8
balaji.bandi
what nexus code running, can you post the show interface ethx/x (the interface having errors) - also post other device same output.
also worth refer below thread :
https://community.cisco.com/t5/routing/output-errors-on-port-nexus-5020/td-p/3339391
BB
Hi @balaji.bandi
Thank you for your reply.
Software
BIOS: version 2.1.7
Power Sequencer Firmware:
Module 1: v4.0
Module 1: v4.0
Fabric Power Sequencer Firmware: Module 1: version v4.0
Microcontroller Firmware: version v0.0.0.15
QSFP Microcontroller Firmware:
Module 1: v2.0.0.0
CXP Microcontroller Firmware:
Module not detected
kickstart: version 7.2(1)N1(1)
system: version 7.2(1)N1(1)
BIOS compile time: 06/16/2016
kickstart image file is: bootflash:///n6000-uk9-kickstart.7.2.1.N1.1.bin
kickstart compile time: 10/14/2015 19:00:00 [10/15/2015 06:02:08]
system image file is: bootflash:///n6000-uk9.7.2.1.N1.1.bin
system compile time: 10/14/2015 19:00:00 [10/15/2015 06:02:52]
# sh int eth1/41
Ethernet1/41 is up
Dedicated Interface
Belongs to Po107
MTU 1500 bytes, BW 10000000 Kbit,, BW 10000000 Kbit, DLY 10 usec
reliability 245/255, txload 1/255, rxload 1/255
Encapsulation ARPA, medium is broadcast
Port mode is fex-fabric
full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped 00:18:44
Last clearing of "show interface" counters 00:45:41
1 interface resets
30 seconds input rate 528416 bits/sec, 148 packets/sec
30 seconds output rate 383688 bits/sec, 276 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 544.43 Kbps, 125 pps; output rate 495.91 Kbps, 261 pps
RX
385920 unicast packets 12890 multicast packets 187 broadcast packets
453051 input packets 180239096 bytes
34097 jumbo packets 0 storm suppression bytes
0 runts 0 giants 54054 CRC 0 no buffer
54054 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
420972 unicast packets 498015 multicast packets 13116 broadcast packets
937163 output packets 207331121 bytes
23355 jumbo packets
2003 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
Eth1/41 is part of port-channel connected to FEX
is this nexus in vPC ? is the FEX is dual-homed uplink?
what is the other interface part of port-channel ?
Can you post same information from other interface ? does it show same errors /
Can you post -
show interface  Eth1/41 counters detailed all
BB
Hi @balaji.bandi @MHM Cisco World
The issue seems to be related to the Fex device, please see the below errors:
2022 Oct 25 06:47:04.959 hkghke-5k-02 %VMM-2-VMM_SERVICE_ERR: VDC1: Service SAP 175 for slot 40 (FEX chassis 107) returned error 0x40290126 (Communication with port client failed.) in if_bind sequence
2022 Oct 25 06:47:04.959 hkghke-5k-02 %IM-3-IM_RESP_ERROR: Component MTS_SAP_VMM opcode:MTS_OPC_IM_IF_VDC_BIND in vdc:1 returned error:Communication with port client failed.
2022 Oct 25 06:47:04.960 hkghke-5k-02 %IM-3-IM_SEQ_ERROR: Error (Communication with port client failed.) while communicating with component <Internal Error> opcode:N/A (for:RID_MODULE: 40)
Can you post -
Rather jumping, i expect to address the questions asked before.
also what FEX Model is this ?
can you post  - show fex 107
Also worth looking at some Bugs below :
https://bst.cisco.com/bugsearch/bug/CSCuw48505
BB
Hi Balaji,
I shutdown the physical port with Fex 107, as it was impacting the production environment so I can't provide all details.
However please see the below:
# sh int counter err | egrep "Port|--|\B [1-9]" | egrep -v "\ 0\ *--\ *0\ *0\ *0\ *0"
Port          Align-Err    FCS-Err   Xmit-Err    Rcv-Err  UnderSize OutDiscards
Eth1/1                0          0    1795208          0          0           0
Eth1/2                0          0     114651          0          0           0
Eth1/9                0          0     190495          0          0           0
Eth1/17               1         12          0         13          0           0
Eth1/33               0          0     101461          0          0           0
Eth1/41               0      91130          0      91130          0           0
Po17                  1         12          0         13          0           0
Po101                 0          0    1795208          0          0           0
Po103                 0          0     114651          0          0           0
Po105                 0          0     190495          0          0           0
Po107                 0      91141          0      91141          0           0
Po109                 0          0     101461          0          0           0
The Fex model is Extender Model: N2K-C2232PP-10GE, this is a capture from the Fex log( this is when we tried to change the Fex Uplink port):
10/24/2022 20:35:38.686629: Module Online Sequence
10/24/2022 20:36:32.870033: Aborting lc insert sequence
10/24/2022 20:36:32.870100: Deleting route to FEX
10/24/2022 20:36:32.878377: Module disconnected
10/24/2022 20:36:32.879500: Module insert failed
10/24/2022 20:36:32.880375: Module Offline Sequence
10/24/2022 20:36:32.992234: Module Offline
The Fex was flapping continuously. Please note that this Fex is a single-homed Uplink.
https://community.cisco.com/t5/switching/nexus-5672-output-to-fex-errors/td-p/3221074
you have issue with jumbo frame in NSK,
check if the frame is come from jumbo to 1500 mtu port
can we see show interface,
when need to see error
