03-16-2023 07:12 AM
Hi, I want to enable jumbo frames bettwen nexus 9300 and cat3850.
nexus is on NXOS: version 9.3(8)
cat is on IOS XE Software, Version 16.09.05
On nexus side I have set
sh int po1
interface port-channel1
description MTU9k
switchport access vlan 555
mtu 9216
vpc 26
member of portchannel is eth24
interface Ethernet1/26
description MTU9k
mtu 9216
channel-group 26 mode active
Cat3850 conf is:
Global Ethernet MTU is 9000 bytes.
interface Port-channel2
description MTU9k
switchport mode access
Members in this channel: Gi1/0/20 Gi2/0/20
interface GigabitEthernet1/0/20
description MTU9k
channel-group 2 mode active
interface GigabitEthernet2/0/20
description MTU9k
when I try to ping from cat to nexus it works. But if I set size to anything above
03-16-2023 07:14 AM - edited 03-16-2023 07:14 AM
when I try to ping from cat to nexus it works. But if I set size to anything above 1500 it fails. What am I missing?
03-16-2023 07:24 AM
03-16-2023 07:28 AM
Hi, thanks for replay.
cat3850 conf is:
Is this OK?
Also:
I am not shure about this one
sh vlan mtu
VLAN SVI_MTU MinMTU(port) MaxMTU(port) MTU_Mismatch
555- 9000 9000 No
Is ti OK to have value 9000 on SVI_MTU on vlan555?
03-16-2023 08:06 AM - edited 03-16-2023 08:08 AM
sorry you already config MTU in global mode of 3850. so that OK
for NSK
Nexus 3000: Includes Nexus 3132Q-V, 3164, 31108, 31128PQ, 3200 Series, and 36180YC-R switches
Neuxs 7000: All Nexus 7000- and 7700 Series switches
Nexus 9000: All Nexus 9200 Series switches (includes 92xxx), 9300 Series switches (includes 93xxx), and 9500 Series switches
For platforms that use Per-Port MTU Configuration L2 ports can use only the System Jumbo MTU configured on the switch or 1500. By default System Jumbo MTU is 9216.
L2 ports configured with Jumbo MTU automatically updates to the new value if it is changed.
Nexus# show running-config all | i jumbomtu
system jumbomtu 9216
Nexus(config)# system jumbomtu ?
<1500-9216> Enter jumbomtu
Configure and Verify Maximum Transmission Unit on Nexus Platforms - Cisco
03-16-2023 08:34 AM
Hi is it really nessesary to enable system mtu to 9000? I am really not comfortable with that. I am not shure waht will happend. I have mtu 9216 enabled on portchannel and phy int. Also, there are two hosts on nexus and Jumbos are flying wheel bettween them. Only problem is that Jumbos are not working bettwen switches.
03-16-2023 10:37 AM
If this is just for layer-2 traffic between the switches, you don't need to enable system mtu on the nexus. All you need is "mtu 9216" under the physical interface or Portchannels. To verify the mtu is applied correctly, use "sh int ex/x | in MTU"
03-17-2023 04:18 AM
I will share note with you, today or tomorrow.
03-17-2023 08:06 AM
I dont why the Cisco make it more complex
first the platform divide into two
platform that not support MTU under interface
platform that support MTU under interface, here the MTU you config under the interface (per-port) must be within range the jumbo frame size you config in system.
to be sure I run lab and check this point.
thanks
MHM
03-22-2023 06:48 AM
First, I am sorry.
System mtu 9000/9216 is enabled on both switches.
Only nexus have mtu set to 9216 on port.
All hosts are in same vlan.
jumbo works between hosts on nexus and also between hosts on 3850, but jumbo is still not working between switches.
Is there any diagnostic tool or log so I can figure out what I am doing wrong?
03-22-2023 07:00 AM
can you try ping from Host not from NSK or SW,
the MTU jumbo size have two level
for L2 you can config under L2 port
and L3 you must config it under SVI
but to be sure ping from Host in Cat to Host in NSK with large MTU size.
12-07-2024 09:12 AM - edited 12-07-2024 09:34 AM
Based on what I'm seeing (not quite finished the testing), it looks like Cisco have made this easy on Cat9k, but still lots of work is needed on N9k. For Cat9k this one global command will consider everything MTU 9198 and OSPF will pick it up too. You can then drop the MTU on certain interfaces if it's really necessary:
N9k(config)# system jumbomtu ?
! set "mtu" on all layer2 interfaces:
interface Ethernet1/1
switchport
switchport access vlan 200
mtu 9216
! Also set "mtu" where interface has an IP:
interface VlanX
description 10.0.0.0/30_P2P
mtu 9198
ip address 10.0.0.1/30
interface Ethernet1/52
mtu 9198
ip address 10.0.254.0/31
cat9k(config)#system mtu ?
<1500-9198> MTU size in bytes
The Cat9k config seems to take care of L2 and L3 interfaces in one shot and seems better suited to networks in 2024+ where we're dealing with things like VXLAN.
