Jumbo Frames not Working cisco 9300 or 3650
Hello Friends. We have a situation.
Current Setup:-   VMware-->Cisco 3750-->>NetApp iscsi. Jumbo frames enabled mtu 9000 bytes. VMWare Storage Resides on NetApp Via ISCSI using switch 3750.
We would like to replace the cisco 3750 with Catalyst 3650. Exact same configuration. The issue we are running into is when we move our connections from (existing 3750) to new 3650, vmware gets stuck on refreshing the storage. The weird thing is we can ping everything from all devices, it's just the storage cannot be scanned and updated. That is the only reason I'm thinkin the Global MTU on new 3650 should be 9000 (same as existing 3750) or should it be set to max which is 9198 bytes. Any help/assistance would be appreciated.
37 Replies 37
same config
Note
: Gigabit Ethernet ports are not affected by the system mtu command; 10/100 ports are not affected by the system mtu jumbo command. If you do not configure the system mtu jumbo command, the set of the system mtu command applies to all Gigabit Ethernet interfaces.
Tried it.. Still not passing the Jumbo Frames.
Here is what I have tried until now..
set mtu to 9000/9198 on per port basis and reboot and tested. still same..
Here is existing/new topology
existing topology:
VMware host( VMNIC's configured to MTU 9000)-->> Cisco 3750X Switch (Ports in use configured to MTU9000/9198)-->> NetAPP iscsi Storage (MTU 9000). Everything works fine and vmware host can rescan/see/connect to the storage via iscsi with no issues.
New Topology (with Switch Replacement)
VMware host( VMNIC's configured to MTU 9000)-->> Cisco 9300 Switch (Ports in use configured to MTU9000/9198)-->> NetAPP iscsi Storage (MTU 9000).  In this,  vmware host cannot rescan/see/connect to the Netapp storage via iscsi..
Any help would be appreciated..
set global system mtu to 9000 or 9198, reboot and tested, still vmware cannot connect to storage via iscsi..
are the OLD design use Access interface and new design use trunk ? you must keep in mind that there are extra 4 bytes for VLAN if the connection via trunk
No. Exact same setup. Both connections are using Trunk.
show system mtu
show interfaces mtu
show int gige x/x | i MTU
Here you go..
Server-Switch3#show int gi 1/1/1 | i MTU
MTU 9198 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Server-Switch3#sh int
Server-Switch3#sh interfaces mtu
Port Name MTU
Gi1/0/1 Trunk port to core 9198
Gi1/0/2 new host 9000
Gi1/0/3 Temporary Connecti 9000
Gi1/0/4 New VM HOST 9000
Gi1/0/5 Vmware ESXi 5.5 se 9000
Gi1/0/6 New VM HOST 9000
Gi1/0/7 New VM HOST 9000
Gi1/0/8 Server 9000
Gi1/0/9 New VM HOST 9000
Gi1/0/10 HOST 1 9000
Gi1/0/11 HOST 1 9000
Gi1/0/12 DUAL HOME ESXi VM2 9000
Gi1/0/13 New Host 9000
Gi1/0/14 servers 9000
Gi1/0/15 servers 9000
Gi1/0/16 New Host 3 9198
Gi1/0/17 CV-CBB-Backup-Host 9000
Gi1/0/18 LSECV01-CBB-Physic 9000
Gi1/0/19 New Host 3 9198
Gi1/0/20 Servers 9000
Gi1/0/21 Link to HP VM by 9000
Port Name MTU
Gi1/0/22 Link to HP VM by 9000
Gi1/0/23 DUAL HOME ESXi VM2 9000
Gi1/0/24 DUAL HOME ESXi VM1 9198
Gi1/1/1 TO STORAGE CONTROL 9198
Gi1/1/2 TO STORAGE CONTROL 9000
Gi1/1/3 LSE STORAGE MGMT P 9198
Gi1/1/4 9198
Ap1/0/1 9198
Gi2/0/1 Trunk port to core 9198
Gi2/0/2 Trunk Ports 9000
Gi2/0/3 Vmotion VM3 9000
Gi2/0/4 9000
Gi2/0/5 Vmware ESXi 5.5 se 9000
Gi2/0/6 Vmotion VM1 9000
Gi2/0/7 New Host 9000
Gi2/0/8 Servers Backup Lin 9000
Gi2/0/9 Servers Backup Lin 9000
Gi2/0/10 DUAL HOME ESXi VM2 9000
Gi2/0/11 Servers Backup Lin 9000
Gi2/0/12 Server 9000
Gi2/0/13 Servers Backup Lin 9000
Gi2/0/14 HOST 1 9000
Gi2/0/15 HOST 1 9000
Port Name MTU
Gi2/0/16 New VM HOST 9198
Gi2/0/17 LSEDSO2-nic2 9000
Gi2/0/18 LSEDSO1-nic2 9000
Gi2/0/19 9198
Gi2/0/20 Servers 9000
Gi2/0/21 Link to HP VM by 9000
Gi2/0/22 Link to HP VM by 9000
Gi2/0/23 DUAL HOME ESXi VM2 9000
Gi2/0/24 DUAL HOME ESXi VM1 9198
Gi2/1/1 TO STORAGE CONTROL 9198
Gi2/1/2 TO STORAGE CONTROL 9000
Gi2/1/3 LSE STORAGE MGMT - 9198
Gi2/1/4 9198
Ap2/0/1 9198
Po5 9198
Po6 9000
Po7 9198
Server-Switch3#sh system mtu
Global Ethernet MTU is 9198 bytes.
just I need one more
show interface x/x <<- interface connect to both vm and Netapp
I have switched the connections back. Do you need the live interface? if yes, I'll have to send it that way. Below are the details:-
Interface connected to VM host:- gi 1/0/16,1/0/19,2/0/16,2/0/19
Interface connected to NetAPP:- gi1/1/1, gi2/1/1
Currently nothing is connected and below are the details you requested.. We can switch the connections and resend them:-
Server-Switch3#sh int gi1/0/16
GigabitEthernet1/0/16 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ac7a.5649.b610 (bia ac7a.5649.b610)
Description: New Host 3
Keepalive set (10 sec)
Auto-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 21:46:02, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
95793 packets input, 41159430 bytes, 0 no buffer
Received 10 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
575279 packets output, 520367530 bytes, 0 underruns
Output 115609 broadcasts (76405 multicasts)
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Server-Switch3#sh int gi1/0/19
GigabitEthernet1/0/19 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ac7a.5649.b613 (bia ac7a.5649.b613)
Last input never, output 21:45:27, output hang never
68044 packets input, 20873338 bytes, 0 no buffer
Received 41 broadcasts (0 multicasts)
369554 packets output, 210256597 bytes, 0 underruns
Output 115848 broadcasts (76653 multicasts)
Server-Switch3#sh int gi2/0/16
GigabitEthernet2/0/16 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ac7a.566e.c110 (bia ac7a.566e.c110)
Description: New VM HOST
Last input never, output 21:45:40, output hang never
114 packets input, 14240 bytes, 0 no buffer
Received 8 broadcasts (0 multicasts)
198705 packets output, 35060010 bytes, 0 underruns
Output 115851 broadcasts (76650 multicasts)
Server-Switch3#sh int gi2/0/19
GigabitEthernet2/0/19 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ac7a.566e.c113 (bia ac7a.566e.c113)
Last input never, output 21:45:32, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
198517 packets output, 34979030 bytes, 0 underruns
Output 115939 broadcasts (76691 multicasts)
Server-Switch3#sh int gi1/1/1
GigabitEthernet1/1/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ac7a.5649.b619 (bia ac7a.5649.b619)
Description: TO STORAGE CONTROLLER1
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
Last input 21:45:53, output 21:45:39, output hang never
1766298 packets input, 1706049756 bytes, 0 no buffer
Received 1006 broadcasts (935 multicasts)
0 watchdog, 935 multicast, 0 pause input
105867 packets output, 34570765 bytes, 0 underruns
Output 35484 broadcasts (39972 multicasts)
370 unknown protocol drops
Server-Switch3#sh int gi2/1/1
GigabitEthernet2/1/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ac7a.566e.c119 (bia ac7a.566e.c119)
Keepalive not set
Last input 21:45:43, output 21:45:41, output hang never
1269658 packets input, 1142643020 bytes, 0 no buffer
Received 1046 broadcasts (939 multicasts)
0 watchdog, 939 multicast, 0 pause input
1865691 packets output, 705094171 bytes, 0 underruns
Output 70136 broadcasts (32861 multicasts)
just I want to see if giant count increase in these interface no need life since you dont clear the counter it appear oldest count
okok.. Thanks.. lmk how to proceed, what's the issue what can we try..
1-
C9k#show platform software fed active ifm mappings
Interface IF_ID Inst Asic Core Port SubPort Mac Cntx LPN GPN Type Active
ge x/x 0xF 1 0 1 20 0 16 4 1 101 NIF Y
C9k#show platform software fed active ifm if-id 0xF | inc MTU
Jumbo MTU ............ [9xxx]
2- check the giant frame when connection is life (if you can)
3- share output of below in both case life (if you can) and no connection
c9k#show controllers ethernet-controller ge x/x
Server-Switch3#show platform software fed switch active ifm mappings
Interface IF_ID Inst Asic Core Port SubPort Mac Cntx LPN GP N Type Active
GigabitEthernet2/0/1 0x33 1 0 1 0 0 26 6 1 9 7 NIF Y
GigabitEthernet2/0/2 0x34 1 0 1 1 0 6 7 2 9 8 NIF Y
GigabitEthernet2/0/3 0x35 1 0 1 2 0 28 8 3 9 9 NIF Y
GigabitEthernet2/0/4 0x36 1 0 1 3 0 27 9 4 1 00 NIF Y
GigabitEthernet2/0/5 0x37 1 0 1 4 0 30 10 5 1 01 NIF Y
GigabitEthernet2/0/6 0x38 1 0 1 5 0 29 11 6 1 02 NIF Y
GigabitEthernet2/0/7 0x39 1 0 1 6 0 32 12 7 1 03 NIF Y
GigabitEthernet2/0/8 0x3a 1 0 1 7 0 31 13 8 1 04 NIF Y
GigabitEthernet2/0/9 0x3b 1 0 1 8 0 19 14 9 1 05 NIF Y
GigabitEthernet2/0/10 0x3c 1 0 1 9 0 5 15 10 1 06 NIF Y
GigabitEthernet2/0/11 0x3d 1 0 1 10 0 21 16 11 1 07 NIF Y
GigabitEthernet2/0/12 0x3e 1 0 1 11 0 20 17 12 108 NIF Y
GigabitEthernet2/0/13 0x3f 1 0 1 12 0 23 18 13 109 NIF Y
GigabitEthernet2/0/14 0x40 1 0 1 13 0 22 19 14 110 NIF Y
GigabitEthernet2/0/15 0x41 1 0 1 14 0 25 20 15 111 NIF Y
GigabitEthernet2/0/16 0x42 1 0 1 15 0 24 21 16 112 NIF Y
GigabitEthernet2/0/17 0x43 0 0 0 16 0 26 6 17 113 NIF Y
GigabitEthernet2/0/18 0x44 0 0 0 17 0 6 7 18 114 NIF Y
GigabitEthernet2/0/19 0x45 0 0 0 18 0 28 8 19 115 NIF Y
GigabitEthernet2/0/20 0x46 0 0 0 19 0 27 9 20 116 NIF Y
GigabitEthernet2/0/21 0x47 0 0 0 20 0 30 10 21 117 NIF Y
GigabitEthernet2/0/22 0x48 0 0 0 21 0 29 11 22 118 NIF Y
GigabitEthernet2/0/23 0x49 0 0 0 22 0 32 12 23 119 NIF Y
GigabitEthernet2/0/24 0x4a 0 0 0 23 0 31 13 24 120 NIF Y
GigabitEthernet2/1/1 0x4b 1 0 1 24 0 3 4 25 121 NIF Y
GigabitEthernet2/1/2 0x4c 1 0 1 25 0 2 5 26 122 NIF Y
GigabitEthernet2/1/3 0x4d 0 0 0 26 0 3 4 27 123 NIF Y
GigabitEthernet2/1/4 0x4e 0 0 0 27 0 2 5 28 124 NIF Y
TenGigabitEthernet2/1/1 0x4f 1 0 1 28 0 0 3 29 125 NIF N
TenGigabitEthernet2/1/2 0x50 1 0 1 29 0 0 2 30 126 NIF N
TenGigabitEthernet2/1/3 0x51 1 0 1 30 0 0 1 31 127 NIF N
TenGigabitEthernet2/1/4 0x52 1 0 1 31 0 0 0 32 128 NIF N
TenGigabitEthernet2/1/5 0x53 0 0 0 32 0 0 3 33 129 NIF N
TenGigabitEthernet2/1/6 0x54 0 0 0 33 0 0 2 34 130 NIF N
TenGigabitEthernet2/1/7 0x55 0 0 0 34 0 0 1 35 131 NIF N
TenGigabitEthernet2/1/8 0x56 0 0 0 35 0 0 0 36 132 NIF N
FortyGigabitEthernet2/1/1 0x57 1 0 1 36 0 0 0 37 133 NIF N
FortyGigabitEthernet2/1/2 0x58 0 0 0 37 0 0 0 38 134 NIF N
TwentyFiveGigE2/1/1 0x59 1 0 1 38 0 0 0 39 135 NIF N
TwentyFiveGigE2/1/2 0x5a 0 0 0 39 0 0 0 40 136 NIF N
AppGigabitEthernet2/0/1 0x5b 1 0 1 40 0 11 22 41 137 NIF Y
Server-Switch3#show platform software fed switch active ifm if-id 0xF | inc MTU
Jumbo MTU ............ [0]
