Cat9300 Guestshell Question
HUBERT RESCH
Level 5
Level 5
Hi all,
I already did some deployments with enabled guestshell where we had Catalyst 9300 running as L3-switch.
iox
interface virtualPortGroup 0
 description Gateway for Guestshell
 ip address 172.23.226.1 255.255.255.0
app-hosting appid guestshell
 app-vnic gateway0 virtualportgroup 0 guest-interface 0
  guest-ipaddress 172.23.226.254 netmask 255.255.255.0
app-default-gateway 172.23.226.1 guest-interface 0
Now we want to deploy guestshell on Catalyst9300 running as L2 switch , guestshell should run in the VLAN which is availabe on the Switch (eg. 172.23.226.254. Gateway is on the distribution-switch behind the uplink
vlan 226
ip default-gateway 172.23.226.1
interface range gigabitethernet 1/0/1-48
 switchport mode access
 switchport access vlan 226
interface vlan 226
 description Management
 ip address 172.23.226.100 255.255.255.0
interface Ten 1/1/1
 description Uplink
 switchport mode trunk
 switchport trunk allowed vlan 226
for me it seems this could be done with usage of the Appgigabitethernet-Interface:
 app-vnic AppGigabitEthernet access
  guest-interface 0
interface AppGigabitEthernet1/0/1
It seems to be fine, but the remaining question is how to assigne the IP to guestshell.
Per default the network-interface of guestshell is enabled for DHCP
[guestshell@guestshell network-scripts]$ cat ifcfg-eth0
DEVICE=eth0
BOOTPROTO=dhcp
ONBOOT=yes
HOSTNAME=
NM_CONTROLLED=no
TYPE=Ethernet
MTU=
DHCP_HOSTNAME=guestshell
in vlan 226 there is a DHCP-Server running, but no DHCP-request from guestshell is reaching the DHCP-Server,
I also cannot see any MAC-address in interface App1/0/1.
whats wrong there, anything I understood wrong ??
Thx in Advance
Hubert
andrewswanson
Level 11
Level 11
I've looked at guestshell on Catalyst 3ks running as L2 switches before.
To get Guestshell running I used a virtualportgroup interface and assigned it the Switch's L2 management IP address (using ip unnumbered). In your environment the config would look something like:
interface VirtualPortGroup0
 ip unnumbered Vlan226
hth
Andy
Tony M
Level 2
Level 2
Hello Hubert,
IOSXE Version 17.01.01 accepts this syntax:
 app-vnic AppGigabitEthernet trunk
  vlan 256 guest-interface 0
This does assign the address to eth0 in the guestshell:
[guestshell@guestshell ~]$ sudo ip addr show dev eth0
73: eth0@if74: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 52:54:dd:12:54:78 brd ff:ff:ff:ff:ff:ff link-netnsid 0
    inet 172.23.226.254/24 brd 10.56.31.255 scope global eth0
       valid_lft forever preferred_lft forever
    inet6 fe80::5054:ddff:fe12:5478/64 scope link
The default GW is also configured properly. However, at this point, I am stuck. The network remains unreachable from the guest shell.
Have you been able to make any progress beyond where you were when you originally posted?
Thanks!
Please disregard the incorrect broadcast address in the ip addr show command below. I was replacing the values with the ones you were using but missed one 🙂
Tristan G
Level 2
Level 2
Hi all,
Did anyone get to the bottom of this? Is this configuration supported with guestshell?  I've configured similar on 17.15.1 using similar config. I can see the IP in the ARP table with the correct MAC address, but not in the MAC address table. nor do I see any traffic via tcpdump on the guestshell.
