03-23-2015 08:26 PM - edited 03-07-2019 11:13 PM
I need to enable jumbo frames on a pair of Nexus 5k's that sit between UCS B chassis and Netapp Storage. If I enable it globally using service policy, how will it affect other things connected to the 5k's that aren't using jumbo frames?
03-24-2015 06:50 AM
This may help https://supportforums.cisco.com/document/12168171/configuring-jumbo-mtu-support-nexus-7000-and-5000
03-24-2015 07:16 AM
Thanks Stephen, from that it sounds to me that if I enable jumbo frames system wide on the 5k, only devices that are configured on their end will use jumbo frames and devices connected to the switch that are configured for mtu 1500, will still use 1500.
03-24-2015 07:36 AM
Yes, correct.
Switch is enabled to support only if end hosts send a jumbo frame to it :)
