kron policy not working
Himanshu-Bansal
Hello Team,
today i configured kron policy on one of my switch for automatic configuration backup, but it doesn't work for me as i supposed.
am getting ping from my tftp server and also able to do manual backup from the same device but not automatic.
please help me for the same, below is the configuration for the kron correct me if i left something.
#kron policy-list test
#cli sh run-conf | redirect tftp://192.168.1.4/testbackup.cfg
#exit
#kron occurence dailybackup at 10:00 recurring
#policy-list test
#exit
8 Replies 8
Abzal
Level 7
Level 7
You could do it with script If your router supports Embedded Event Manager:
event manager applet DailyBackup_at_10_00
event timer cron name daily cron-entry "00 10 * * *" maxrun 30
action 1 syslog priority warnings msg "Configuration is Backed Up"
action 2 cli command "enable"
action 3 cli command "copy run tftp://192.168.1.4/testbackup.cfg" pattern "Address"
action 4 cli command "" pattern "Destination"
action 5 cli command ""
http://blog.ine.com/2010/01/18/eem-demystified-part-1/
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Thanks for reply, unfortunately my switch doesn't support EEM, but i tried  kron once again but this time it comes in active state but with error please help me with this error as am not aware of this.
Regard's
himanshu
Ok, tell then the switch model.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
hi,
its 2960G and 3750E series switches.
Regard's
Himanshu.
I am facing the same problem on Cisco 2960 switch. Can anyone pls help.
I think the issue with your setup is the fact that even though you specified all file details the system will ask for confirmation. Can you please try to configure file prompt quiet in global config mode and then schedule the kron job?
glen.grant
  try to rewrite using these instructions.
Automatic Backup of Configuration using the Kron Method
In order to get a router to copy the running-config to startup-config, for example every Sunday at 23:00, complete these steps:
    Create a kron policy list—This is the script that lists what commands the router should run at the scheduled time.
        Router(config)#kron policy-list SaveConfig
                Router(config-kron-policy)#cli write
                Router(config-kron-policy)#exit
        cli—Specifies EXEC CLI commands within a Command Scheduler policy list.
        Policy-list—Specifies the policy list associated with a Command Scheduler occurrence.
    Note: The reason why write was used rather than copy running-config startup-config is because kron does not support interactive prompts and the copy running-config startup-config command requires interaction. It is important to remember this when you create commands. Also, note that kron does not support configuration commands.
    Create a kron occurrence—This informs the router when and how often the policy should run.
        Router(config)#kron occurrence SaveConfigSchedule
         at 23:00 Sun recurring
                Router(config-kron-occurrence)#policy-list SaveConfig
        SaveConfigSchedule—This is the name of occurrence. Length of occurrence-name is from 1 to 31 characters. If the occurrence-name is new, an occurrence structure will be created. If the occurrence-name is not new, the existing occurrence will be edited.
        at—Identifies that the occurrence is to run at a specified calendar date and time.
        recurring—Identifies that the occurrence is to run on a recurring basis.
    Verify the kron configuration by using the show command.
        Router#sh kron schedule
                 Kron Occurrence Schedule
                 SaveConfigSchedule inactive, will run again in 1 days 12:37:47 at 23:00 on Sun
        inactive—Means that kron is not running the command(s) at present.
        Active—Means that kron is running the current command(s).
        Router#show running-configuration
                  kron occurrence SaveConfigSchedule at 23:00 Sun recurring
                    cli write
Backup Configuration to a TFTP Server
This example is to save the running config to a TFTP server (10.1.1.1) every Sunday at 23:00:
    Router(config)#kron policy-list Backup
             Router(config-kron-policy)#cli show run | redirect
         tftp://10.1.1.1/test.cfg
             Router(config)#kron occurrence Backup at 23:00 Sun recurring
             Router(config-kron-occurrence)#policy-list Backup
thanks for reply  glen.grant, i tried above mention configuration but the result is same error.
please help me in this error.
regard's
Himanshu
