Kron problem
Jan Rockstedt
Have C3750 Version 12.2(25r)SEE3
Trying to run:
kron policy-list backup
cli write
cli copy running-config tftp://xx.xx.xx.xx/swi06-confg
kron occurrence backup at 22:00 Mon recurring
policy-list backup
There are nothing backup and nothing in the logg.
Any sugestion?
Regards Jan
Hi Jan,
Kron [Command Schedular] feature is not supported on switches.
Check the feature Navigator -
http://tools.cisco.com/ITDIT/CFN
"kron policy-list list-name" Command was introduced in 12.3.1 IOS -
http://www.cisco.com/en/US/docs/ios/12_3/configfun/command/reference/cfr_1g04.html#wp1049808
-> Sushil
6 Replies 6
Hi Jan,
-> Sushil
Thx,
Strange:
kron policy-list
Release Modification
12.3(1) This command was introduced.
But I have this command in IOS 12.2......
//Jan
Amit Singh
Jan,
You can use EEM insteak of Kron policy to achieve the same. Please have your 3750 to be upgraded to the latest IOS and then download the EEM script for doing the automatic backup of the config.
Link for downloading the EEM Script.
http://forums.cisco.com/eforum/servlet/EEM?page=search_results&fn=search&catId=0&count=20&skip=0&sortBy=3&order=DESC&mode=browse
HTH,Please rate if it does.
-amit singh
Jan,
Have a look at this as well -
http://www.blindhog.net/cisco-automatic-configuration-backup/
-> Sushil
Nice thx. :)
//Jan
andmende
Hi All,
Kron is supported in fixed units.  I just did a recreation in 3560, 3750 and 2960 running 12.2(50) and it worked by creating a back up of the show run in a tftp server.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a008020260d.shtml#ab
Cisco Feature Navigator mentions this is not supported but it worked for me.  Be clear it mentions it does not support interactive commands; however, I am currently testing that.
SW3560#show clo
15:22:32.881 UTC Tue Jan 15 2013
SW3560#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
SW3560(config)#kron policy-li
SW3560(config)#kron policy-list CONFIGBACKUP
SW3560(config-kron-policy)#cli show run | redirect
SW3560(config-kron-policy)#no cli show run | redirect
SW3560(config-kron-policy)#cli show run | redirect tftp://192.168.30.10/test.cfg
SW3560(config-kron-policy)#exit
SW3560(config)#kro
SW3560(config)#kron oc
SW3560(config)#kron occurrence CONFIGBACKUP a
SW3560(config)#kron occurrence CONFIGBACKUP at 15:29 ?
  <1-31>     Day of month
  DAY        Day of Week eg mon, tue, etc
  MONTH      Month of year eg jan, feb, etc
  oneshot    Schedule kron occurrence exactly once
  recurring  Schedule kron occurrence repeatedly
SW3560(config)#kron occurrence CONFIGBACKUP at 15:29 one
SW3560(config)#kron occurrence CONFIGBACKUP at 15:29 oneshot ?
SW3560(config-kron-occurrence)#pol
SW3560(config-kron-occurrence)#policy-list CONFIGBACKUP
SW3560(config-kron-occurrence)#EXIT
SW3560(config)#exit
SW3560#
Jan 15 15:26:52.928: %SYS-5-CONFIG_I: Configured from console by console
SW3560#show kron sched
Kron Occurrence Schedule
CONFIGBACKUP inactive, will run once in 0 days 00:01:55 at 15:29 on
SW3560#
I hope that helps for you.
