Cisco 1141 WAP won't work with Auto Diagnostic tool
rvdsabu4life
We just replaced our Cisco 1240 AP in one of our shops with a Cisco 1141 AP.  This is not controller based.
We use several wireless (infrastructure mode) auto diagnostic tools which connect to the AP.  We also have many laptops which run the diagnostic software.
We had no problems with our 1240AP.  With our 1141, we cannot connect to the wireless tools if both the laptop and the tools are connected to the 1141.  If I connect one to the 1240 and one to the 1141, they can see each other and work fine.  IF they are both connected to the 1141, they show up as connected in the AP, they can ping each other, but the software does not communicate.
It is similiar to this:
https://supportforums.cisco.com/thread/2048621
However, none of his suggestions worked.
What do I need to do different so these connect?
As per your exsisting configuration you dont need those command, so i was suggesting to remove them. I wasn't hoping that this will fix the issue :-)
As per your initial description when both devices are on 1141 AP's you are able to ping between the devices but the software doesn't communicate. Do you have any idea if this software uses multicast by any chance?
To address your problem, have you checked if igmp snopping is enable (by default it is enabled)? Please verify it with below command.
show ip igmp snooping
If it is enabled try disabling it with below command and verify the diagnostic tool if that works.
conf t
no ip igmp snooping
Najaf
Please rate when applicable or helpful !!!
7 Replies 7
kcnajaf
Level 7
Level 7
Could you please share both AP's running configurations?
Najaf
Here is the one for the 1141.  Currently the 1240 AP is at another location.
Current configuration : 2037 bytes
version 12.4
no service pad
service password-encryption
hostname
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no dot11 igmp snooping-helper
dot11 syslog
dot11 ssid Service
   authentication open
   authentication shared
   guest-mode
   no ids mfp client
dot11 ids mfp generator
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 120632578FCC transmit-key
encryption mode wep mandatory
ssid Service
channel 2447
station-role root
beacon period 20
no dot11 qos mode
infrastructure-client
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address
no ip route-cache
ip default-gateway
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/ea
ip radius source-interface BVI1
no cdp run
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
Is this the configuration which is not working? I dont see any ip address on BVI interface so just wondering how this is setup?
If this is the working configuration try disabling infrastructure-client under the radio with below command
confi t
int dot0
no infrastructure-client
also disable dot11 ids mfp generator globally with below command
config t
no dot11 ids mfp generator
Najaf
This is the one that does not work.  I have removed the IP addresses for security purposes
Also, neither of those commands fixed the issue
conf t
no ip igmp snooping
Najaf
This was the problem.  All working good now.  Thanks!
