%L2_AGING-SP-2-DEC_EN_FAIL: Failed to initialize Distributed EtherChannel
ramzi-kotob
The FWSM did not initialize the DEC correctly and I am planning on issuing the command "No monitor session servicemodle" Is this intrusive and to what extent. Will it resolve the issue or do I have to upgrade the IOS. I am running 12.2.18 SXd7B
Giuseppe Larosa
Hello Ramzi,
do it only during a maintanance window the effects can be huge.
Actually we experienced a problem on our webfarm caused by trying to change this monitor session command.
If you can access the FWSM you can verify if the bundle work.
your IOS release is near to the one we use that I think is 12.2(18)SXF9 (I'm not in office now if you like I can tell you next week)
Hope to help
Giuseppe
Giuseppe Larosa
Hello Ramzi,
Hope to help
Giuseppe
Giuseppe,
Thank you for the information. This is very helpfull. Please let me know next week what IOS release you are running.
What do you mean by verify if the bundle wirk in the FWSM. I know the firewall is working properly.
Thank you,
Ramzi
