L2 bridge on 1921 Router interface
bsoth
HI all- I need to set up a L2 llink between my LAN and this 1921 router. I though IRB would do it but its not working yet. Looking for some ideas. Here is the topology- I dont want to see another hop on this 1921 rtr so I hope I can just trunk it or something with IRB. Not working.
Abzal
Level 7
Level 7
If I understood you correctly you want to reach Internet and WAN through g0/1 interface on Router? Correct me if I'm wrong.
Abzal
Best regards,
Abzal
6 Replies 6
Abzal
Level 7
Level 7
Abzal
Best regards,
Abzal
Ill get to the Internet and MPLS in time, right now I need to solve the problem on my LAN reching the L3 interface on the router form the LAN behind the 3750
Ok, then I'll try to help you I never done this before.
On router configure two subinterfaces, with dot1q tag 1 (e.g G0/1.1) and one for MPLS. Then put default route on 3750 pointing to interface G0/1.1. Assign IP address on router G0/1.1 interface from LAN subnet (10.116.1.x). Assign one separate /30 subnet between ASA and Router(G0/0). To access Internet put default route pointing to ASA inside interface.
And port connected to Router configure as trunk on 3750.
Is there any subnet behind MPLS you want to reach?
Abzal
Best regards,
Abzal
There is a simpler way. I havnt done this before either, but I dont think this is the answer im looking for. thanks though
Show me your router configuration. That's interesting case. I'll try to help you.
Abzal
Best regards,
Abzal
Here is teh router config:
sh run
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Connection to Inside_ASA
ip address 10.116.1.3 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description Connection to MPOE_SWT1
no ip address
duplex auto
speed auto
vlan-range dot1q 1 70
  exit-vlan-config
bridge-group 1
ip forward-protocol nd
           ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 10.116.0.0 255.255.248.0 10.116.1.1
ip route 10.116.8.0 255.255.255.0 198.18.106.225
ip route 10.116.9.0 255.255.255.0 198.18.106.225
ip route 10.116.10.0 255.255.255.0 198.18.106.225
ip route 10.116.11.0 255.255.255.0 198.18.106.225
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
MPOE_RTR-1#
