L2/L3 protocol numbers - any documentation ?
mlopacinski
Hello
I often need to find what is number for specified L2/L3 protocol for example: IPX, CDP, VTP, IPV6, ISIS etc.
Does cisco have any documentation for that ?
It makes no sense to remember all those values, but on CCIE exam i will have access only to cisco documentation.
I've looked thru doc but can't find anything (there is some information in ACE module doc but only for upper layers)
Any help ?
Thanx
8 Replies 8
Are you looking for PORT number on which protocols works ??
Smitesh
Also port numbers for protocols based on TCP/UDP.
But most important for me are L2 protocols like: IPX, CDP, VTP, IPV6.
They don't use port numbers.
Suppose that you have mac ACL and want to permit IPX and CDP but block VTP. How would you create such ACL ?
Thanx
have you tried NBAR for the same ??
NBAR supports most of the protocol you mentioned.
Smitesh
According to:
http://www.cisco.com/en/US/docs/ios/ios_xe/qos/configuration/guide/clsfy_traffic_nbar_xe.html#wp1433675
NBAR does not support non-IP traffic.
So it does not support any of: IPX, CDP, VTP, IPV6.
Am i wrong ?
Thanx
Not sure about VTP, but can see CDP in the list below. Although have never tried that
R1(config-cmap)#match protocol ?
  aarp              AppleTalk ARP
  appletalk         AppleTalk
  arp               IP ARP
  bgp               Border Gateway Protocol
  bittorrent        bittorrent
  bridge            Bridging
  bstun             Block Serial Tunnel
  cdp               Cisco Discovery Protocol
  citrix            Citrix Systems Metaframe 3.0
  clns              ISO CLNS
  clns_es           ISO CLNS End System
  clns_is           ISO CLNS Intermediate System
  cmns              ISO CMNS
  compressedtcp     Compressed TCP (VJ)
  cuseeme           CU-SeeMe desktop video conference
  decnet            DECnet
  decnet_node       DECnet Node
  decnet_router-l1  DECnet Router L1
  decnet_router-l2  DECnet Router L2
  dhcp              Dynamic Host Configuration
  directconnect     Direct Connect Version 2.0
  dlsw              Data Link Switching (Direct encapsulation only)
  dns               Domain Name Server lookup
  edonkey           eDonkey
  egp               Exterior Gateway Protocol
  eigrp             Enhanced Interior Gateway Routing Protocol
  exchange          MS-RPC for Exchange
  fasttrack         FastTrack Traffic - KaZaA, Morpheus, Grokster...
  finger            Finger
  ftp               File Transfer Protocol
  gnutella          Gnutella Version2 Traffic - BearShare, Shareeza, Morpheus
  gopher            Gopher
  gre               Generic Routing Encapsulation
  h323              H323 Protocol
  http              World Wide Web traffic
  icmp              Internet Control Message
  imap              Internet Message Access Protocol
  ip                IP
  ipinip            IP in IP (encapsulation)
  ipsec             IP Security Protocol (ESP/AH)
  ipv6              IPV6
  ipx               Novell IPX
  irc               Internet Relay Chat
  kazaa2            Kazaa Version 2
  kerberos          Kerberos
  l2tp              L2F/L2TP tunnel
  ldap              Lightweight Directory Access Protocol
  llc2              llc2
  mgcp              Media Gateway Control Protocol
  netbios           NetBIOS
  netshow           Microsoft Netshow
  nfs               Network File System
  nntp              Network News Transfer Protocol
  notes             Lotus Notes(R)
  novadigm          Novadigm EDM
  ntp               Network Time Protocol
  ospf              Open Shortest Path First
  pad               PAD links
  pcanywhere        Symantec pcANYWHERE
  pop3              Post Office Protocol
  pppoe             PPP over Ethernet
  pptp              Point-to-Point Tunneling Protocol
  printer           print spooler/lpd
  qllc              qllc protocol
  rcmd              BSD r-commands (rsh, rlogin, rexec)
  rip               Routing Information Protocol
  rsrb              Remote Source-Route Bridging
  rsvp              Resource Reservation Protocol
  rtcp              Real Time Control Protocol
  rtp               Real Time Protocol
  rtsp              Real Time Streaming Protocol
  secure-ftp        FTP over TLS/SSL
  secure-http       Secured HTTP
  secure-imap       Internet Message Access Protocol over TLS/SSL
  secure-irc        Internet Relay Chat over TLS/SSL
  secure-ldap       Lightweight Directory Access Protocol over TLS/SSL
  secure-nntp       Network News Transfer Protocol over TLS/SSL
  secure-pop3       Post Office Protocol over TLS/SSL
  secure-telnet     Telnet over TLS/SSL
  sip               Session Initiation Protocol
  skinny            Skinny Protocol
  skype             Skype Peer-to-Peer Internet Telephony Protocol
  smtp              Simple Mail Transfer Protocol
  snapshot          Snapshot routing support
  snmp              Simple Network Management Protocol
  socks             SOCKS
  sqlnet            SQL*NET for Oracle
  sqlserver         MS SQL Server
  ssh               Secured Shell
  streamwork        Xing Technology StreamWorks player
  stun              Serial Tunnel
  sunrpc            Sun RPC
  syslog            System Logging Utility
  telnet            Telnet
  tftp              Trivial File Transfer Protocol
  vdolive           VDOLive streaming video
  vofr              voice over Frame Relay packets
  winmx             WinMx file-sharing application
  xwindows          X-Windows remote access
Smitesh
I do not think it will work (can't check right now). Moreover there are many situations in which i can't use class-map and can't use NBAR. The list you show is short and does not cover a whole bunch of protocols like VTP,STP,DTP,LLDP...
That's why i need L2 protocol numbers list somewhere is cisco docs....
I do not belive they force CCIE candidate to remember all possible numbers...
Aren't we looking for more complicated ways to stop VTP, STP, CDP and DTP; when we can simply disable them.
Though I understand your concern. I also don't believe Cisco will want any candidate to cram all the values. However, since it is CCIE exams, it is best said that expect the unexpected if you want to succeed.
As far as docs on them is concerns, let me assured you that you will definately find on cisco, however all the infomation will be distributed and not centrallised. You may have to do lots of browsing to come to the correct page.
PS: I guess the doing lot of broswing on UniverCD will always benifit you as during LAB only help at your disposal will be univerCD. So better practise it now, even though you don't find what you need.
HTH,
Smiteshh
Yes - for CCIE i have to expect unexpected
I've already done a lot of browsing and know docs quite well. For layers 3,4 and up there are valuable informations in ACE modules docs. But for layer2 protocols could not find any table with numbers for each protocol
