L2 switch default gateway clarification
grapevine
I have an L2 switch that has 2 SVIs 172.18.16.51 and 10.145.16.250 with default gateway 172.18.16.1 It's connected to a firewall, firewall has gateway interface 10.145.16.1 and also a meraki and a firewall with gateway 172.18.16.1
If I want to reach 10.145.16.250 from another network (VPN 10.250.1.0) connected to firewall with gateway 10.140.16.1 should the default gateway on switch be changed to 10.145.16.1. I am able to ping the switch from the firewall directly but when I try to reach via VPN from the gateway connected to 10.145.16.1 it says ICMP aged out on the connected Palo Alto firewall. Please advise how to fix this.
Then you are good. Just move the gateway
7 Replies 7
@grapevine
If you have 172.18.16.1 as default Gateway on the switch, If you ping the switch from a different network, the switch will sendo the traffic to default-gateway. 172.18.16.1.
Run a trave route from VPN and see where It stops. This can be missing rules on firewall or route missing on the gateway
grapevine
grapevine
172.18.16.51 is reachable from VPN gateway 1, 1 need 10.145.16.250 reachable from vpn gateway 2, should  I change the default gateway on the switch to 10.145.16.1
If you change the gateway to 10.145.16.1 it might work but you probably will loose access from VPN1 if 10.145.16.1 does not have route to VPN1
grapevine
We are migrating from 172.18 to 10.145 network.so we don't want access to 172. 18. all devices will be moved to 10.145 network
Hello @grapevine
Change the Default Gateway to 10.145.16.1 and / configure a Static Route for VPN Traffic #ip route 10.250.1.0 255.255.255.0 10.145.16.1
Ensures that replies to VPN traffic (10.250.1.xx) go through 10.145.16.1 instead of the default gateway
Thanks !
