l2 switch manageable with intervlan
anand kumar
Hi All,
whats the minimal cost switch that supports intervlan routing and is manageable.
eg:WS-C2960-24TC-S or WS-C2960-8TC-L
mahmoodmkl
Level 7
Level 7
This switch is a pure L2 which will not support intervlan routing but this is managebale.
I suggest u look for 3560 Series which will support intervlan routing.
Sandeep Choudhary
Hi Anand ,
Intervlan supports only on Layer 3 switches or on router.
Like:
Layer-3-Switches (Catalyst 4500/4500-E, Catalyst 3560/3560-E or Catalyst 3750/3750-E Series)
Please rate if it helps.
dsolangon
You can use 12 port 3750 or 3560. With ipbase iOS image . That will support interval routing. That is the cheapest layer enterprise of Cisco
vann_will
Also you could buy a used Cisco 3550 which will do Layer 3 and come out very cheap with this device.  But if money is an issue at this moment try to use packet tracer because it will also do the job for you until you are able to get a L3 Device.
Hope this helps
