L2 vlans allowed over L3 interface?
clybumat1
I have been tasked with creating L3 interfaces between 5 core switches located in different buildings so they can communicate with each other.
We have several L2 vlans that need to span the campus, and I'd like to use these same L3 connections for them.
Is it possible to have a L3 interface between the cores, but also allow several vlans over it?
Could I make a new interface vlan, setup the inter-core connections on this vlan, then allow the L2 vlan spans over this same link?  Or is their another design that would follow best practice?
Joseph W. Doherty
No, you cannot pass a L2 VLAN through a L3 interface unless you use a L2 tunneling protocol, e.g. L2TPv2.
However, you can easily have L3 on top of L2 trunks.  As long as L3 interfaces connect to VLAN running across the trunk, you can pass L3 traffic.  On L3 switches, you only need to define a SVI.  The VLAN being used could be dedicated just for L3 traffic between both ends of a trunk, logically functioning as a L3 p2p.  You could also have "real" routers connect to a L2 switch access port that provides the transit VLAN.
e.g.
rtr
int faste 0
 desc connects to l2switch f0/0
 ip address 192.168.1.1 255.255.255.252
l2switch
vlan 2
 name Data2
vlan 3
 name Data3
vlan 99
 name p2p
int faste 0/0
 desc connects to rtr f0
 switchport
 switchport mode access
 switchport access vlan 99
int faste 0/1
 desc connects to l3switch f0/0
 switchport
 switchport mode trunk
 switchport trunk allowed vlan 2 , 3 , 99
l3switch
vlan 2
 name Data2
vlan 3
 name Data3
vlan 99
 name p2p
int fast 0/0
 desc connects to l2switch f0/1
 switchport
int vlan 99
 ip address 192.168.1.2 255.255.255.252
7 Replies 7
Julio E. Moisa
If you are going to use L3 links between your switches you should use a routing protocol like ospf, eigrp, etc to communicate the networks of each core switch, remember the L3 devices will not propagate broadcast domains, so the vlans will not be propagated to other core switches.
You could pass the vlans through your network if you are using trunk interfaces between the core switches, layer 2 links.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Yes, we are using EIGRP.  I was planning to advertise this new vlan/network for the L3 interfaces in EIGRP.
The reason why I want to use the same L3 interface for the L2 vlan spans so we don't have to run additional fiber for the trunk interfaces.  Those long range SFPs are expensive these days.. :)
Joseph W. Doherty
e.g.
rtr
int faste 0
l2switch
vlan 2
 name Data2
vlan 3
 name Data3
vlan 99
 name p2p
int faste 0/0
 switchport
int faste 0/1
 switchport
l3switch
vlan 2
 name Data2
vlan 3
 name Data3
vlan 99
 name p2p
int fast 0/0
 switchport
int vlan 99
Ok, I think were getting closer here.  Only thing that's throwing me off is the L2 switches you mention.  These are all Layer 3 core switches that will be connected together.
I think that was just an example of how a L2 switch could sit between a router and a L3 switch and pass the vlan that you are using for routing.
Basically for each switch to switch trunk connection you have a dedicated vlan just for the link ie. no end devices in it and this vlan is dfferent per link so it does not span the campus. This vlan is the one you use to route traffic.
In addition, only for the vlans you need to span the campus you allow those on all the trunks.
So if the vlan isn't allowed on the trunk then it's traffic will be routed which I think is what you want.
Jon
Exactly!
My example showed how it could be done with a router attached to a L2 switch, or a L3 switch, i.e. you could have rtr<access>L2<trunk>L2<access>rtr, rtr<access>L2<trunk>L3 (as shown) or L3<trunk>L3.
Ok, so this is working great so far in packet tracer.
This is my topology.  I am able to ping from one server to the other.
