L2NAT on IE2000 Packet Tracer HELP PLEASE!!
Hi!
I was hoping if I can obtain some assistance with l2nat. I can't seem to get this working. I am trying to implement the network below. The goal is to be able to do L2 NAT Translation from 192.168.1.2 to 10.61.72.5. configurations below:
PC1:
IP: 10.61.72.3
Subnet Mask: 255.255.255.0
Default-Gateway: 10.61.72.1
PC2:
IP: 192.168.1.2
Default-Gateway: 192.168.1.1
SW (10.61.72.1)
version 15.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip cef
no ipv6 cef
ptp mode e2etransparent
license boot level enhancedlanbase
spanning-tree mode pvst
interface FastEthernet1/1
switchport access vlan 721
switchport mode access
switchport nonegotiate
spanning-tree portfast
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface GigabitEthernet1/1
switchport trunk native vlan 721
switchport mode trunk
interface GigabitEthernet1/2
interface Vlan1
no ip address
shutdown
interface Vlan721
mac-address 0001.96ca.1a01
ip address 10.61.72.1 255.255.255.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
SW (10.61.72.2)
Current configuration : 1779 bytes
version 15.2
hostname Switch
no ip cef
no ipv6 cef
l2nat instance NAT
instance-id 1
fixup arp
fixup icmp
inside from host 192.168.1.2 to 10.61.72.5
l2nat NAT 721
interface Vlan1
no ip address
shutdown
interface Vlan721
ip address 10.61.72.2 255.255.255.0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
pieterh
I'm not sure if this is the problem, but the default gateway 192.168.1.1 is not present in your network
even if your goal is to configure L2 config only, as packet tracer is "only" an emulator this may cause the problem
try adding 192.168.1.1 as a secundary address on the switch that is next-hop of the pc
