L2TPv3 Tunnel Not Connecting
perptech1
I am trying to extend Vlan 8 from siteA to siteB, but the tunnel is not coming up. I have attached both sites running configs, so if anyone can shed light on this, I'd appreciate it.
concourse-2801#sh l2tun tunnel
%No active L2TP tunnels
concourse-2801#sh l2tun session
L2TP Session Information Total tunnels 0 sessions 1
LocID      RemID      TunID      Username, Intf/      State  Last Chg Uniq ID
                                 Vcid, Circuit
1          1          n/a        1, Fa0/1.8:8         est    18w0d    1
concourse-2801#
usaf-kc-nlan-rtr#sh l2tun session
                                 Vcid, Circuit
1          1          n/a        1, Fa0/1.8:8         est    1w0d     4
6 Replies 6
Peter Paluch
Jason,
Do you have any particular need to set up the L2TP protocol session values manually, instead of letting the L2TP handle the session establishement in its competence? I believe that letting the L2TP handle the session and tunnel establishement would solve your issue, as this is a basic L2TP pseudowire.
Best regards,
Peter
peter,
thanks for the information. we have no particular need for manually setting them up.
jason
Hi Jason,
In such case, I suggest correcting your configuration as follows:
pseudowire-class l2tp-auto
encapsulation l2tpv3
protocol l2tpv3
ip local interface Loopback1
! For the first router:
interface FastEthernet0/1.8
xconnect 4.4.4.4 1 pw-class l2tp-auto
! For the second router:
xconnect 2.2.2.2 1 pw-class l2tp-auto
This should do the trick.
Best regards,
Peter
Peter,
That worked like a charm. Thanks!
Jason
peter,
jason
I have the following routers
Router 1
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            192.168.192.20  YES NVRAM  up                    up
FastEthernet0/1            63.232.181.14   YES NVRAM  up                    up
FastEthernet0/3/0          10.1.1.3        YES NVRAM  up                    up
NVI0                       192.168.192.20  YES unset  up                    up
Multilink88                65.102.24.102   YES NVRAM  administratively down down
Router 2
GigabitEthernet0/0         10.4.52.10      YES NVRAM  up                    up
GigabitEthernet0/1         172.31.150.2    YES NVRAM  administratively down down
Serial0/0/0:0              unassigned      YES NVRAM  up                    up
Serial0/0/1:0              unassigned      YES NVRAM  up                    up
Serial0/1/0                unassigned      YES NVRAM  up                    up
Multilink1                 65.102.24.134   YES NVRAM  up                    up
I understand that I need to create a pseudowire-class l2tp-auto entry, but would I do it on my g0/0 interface since that is the vlan I want to extend from router 2? And would I create a simular entry on router 1 FastEthernet0/3/0 since that is the vlan I want it to reach?  I appreciate all help.
