L2TPv3 vs DLSW for Bridging VLANs
terrygwazdosky
I'm currently using DLSW to bridge  a VLAN to a remote site and it works fine.  I've been reading up on  L2TPv3 and now I'm wondering if one is better than the other for my  purposes (my hardware will support both), especially if multiple VLANS  are being bridged to the remote site.
We do not have an MPLS infrastructure, so that's not an option.
Thanks.
andrew.prince
Level 10
Level 10
If it's not broken don't fix it......in my opinion
I have the following routers
Router 1
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            192.168.192.20  YES NVRAM  up                    up
FastEthernet0/1            63.232.181.14   YES NVRAM  up                    up
FastEthernet0/3/0          10.1.1.3        YES NVRAM  up                    up
NVI0                       192.168.192.20  YES unset  up                    up
Multilink88                65.102.24.102   YES NVRAM  administratively down down
Router 2
GigabitEthernet0/0         10.4.52.10      YES NVRAM  up                    up
GigabitEthernet0/1         172.31.150.2    YES NVRAM  administratively down down
Serial0/0/0:0              unassigned      YES NVRAM  up                    up
Serial0/0/1:0              unassigned      YES NVRAM  up                    up
Serial0/1/0                unassigned      YES NVRAM  up                    up
Multilink1                 65.102.24.134   YES NVRAM  up                    up
I understand that I need to create a pseudowire-class  l2tp-auto entry, but would I do it on my g0/0 interface since that is  the vlan I want to extend from router 2? And would I create a simular  entry on router 1 FastEthernet0/3/0 since that is the vlan I want it to reach?  I appreciate all help.
