L3 Span
chrisayres
Simple question. Is it possible to SPAN over L3.
bjw
Level 4
Level 4
SPAN related to an interface of port, and all the traffic that passes it.
The Switched Port Analyzer (SPAN) enables you to mirror traffic on any port for analysis by a sniffer or RMON probe. The SPAN directs traffic from a GigEthernet Ethernet or Fast Ethernet port or VLAN to an GigEthernet Ethernet or Fast Ethernet monitor port for detailed analysis and troubleshooting.
You can monitor a single port or VLAN using a sniffer or remote monitoring (RMON) probe like the a Cisco SwitchProbe.
An RMON probe analysis of the remaining five RMON groups.
The closest you might get to specific L3 information would be to span a VLAN that might pass traffic over the L3 subnet that you are looking for.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/rmon.htm
This deosn't really answer the question I am asking.
I want to monitor a port or VLAN on a switch and set the destination port as a port on another switch that is not part of the same L2 network (so I can't use RSPAN).
I think you can use RSPAN, it uses an RSPAN VLAN that brings a source port on a switch to a destination port on a 2nd switch and the source vlan is configurable in RSPAN.
Theoretically it trunks the SPAN session to wherever you need it using a dedicated RSPAN VLAN. But note that RSPAN doesn't support L2 stuff like CDP, DTP, etc. I always recommend spanning locally when possible.
Check out the RSPAN configs:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080441ff6.html
